Tire size question
Discussion in 'The Hokey Ass Message Board' started by modelacitizen, Mar 17, 2010.
  1. modelacitizen
    modelacitizen
    I have s10 spares on the front of my A coupe right now. They look awesome but obviously I'm not gonna be doing much driving with temporary tires on there. I really like the size of the setup though. They are 155/90 -16 on a 16x4 steel wheel. I'm wondering what equivalent tire size I might be able to find. I'd love to get some sort of radial on there... but I know they generally don't come that skinny.... will I have to use a bias ply tube tire? Like a 500x16?? I'm just not sure.
  2. 51 MERC-CT
    51 MERC-CT
    Consider motorcyle tires:):D
  3. Chris 50
    Chris 50
    Try the Coker Excelsiors. Radial tires with bias ply looks and sizes. Get your Alliance membership and save some dough in the process.
  4. modelacitizen
    modelacitizen
    Lol I actually did but I don't think the side wall is sturdy enough. I'd probably be better off just keeping the spares on there and never driving over 50mph! haha ( in regards to bike tires)
  5. Von Rigg Fink
    Von Rigg Fink
    from Garage
    yeah..smart move..
    motorcycle tires are not designed for the side loads..especially the side loads for using as front tires.
    i think you may have to conciter 15's as a wheel size..and i think there is still a 155 series out there..used for the VW crowd..
    dont give up until you have to
  6. Drag Raised
    Drag Raised
    from Quincy, IL
    You'll likely have to go to a 15 inch rim. You'll then have several options available in radials such as a 145-80-15, 155-60-15, 155-80-15 and 165-80-15.
  7. coryw
    coryw
    from Omaha, NE
    Doing the math on the tire sizes Drag Raised gave, the 165-80-15 will be the same width (within tire mfr's variances at least) and roughly 1.5" shorter overall (diameter) than the S10 spares you're running now (drop the front 3/4" roughly).
  8. Gene@Gearworksmfg
    Gene@Gearworksmfg
    165/80R15s have been a very common size to use a front runners. Like Coryw said, the vary slightly between the mfg, so the height is usually around 25" tall.
    Shameless plug..I have new 165s for $50 each
  9. RDAH
    RDAH
    from NL, WI
    Speedway Motors has 3 different narrow radials in there catalog
  10. modelacitizen
    modelacitizen
    That's good to know. Right now my caster is at exactly 7. I'm slightly concerned that dropping it another .75" in the front would throw that off... maybe I could just let more air outta the back tires... LOL
  11. Imwalkin
    Imwalkin
    from Tucson, Az
    175-60-16 at tire easy.com. A tad over 24"tall and about 70 each.
  12. ENFO
    ENFO
    from Tucson AZ
    A buddy of mine has motorcycle tires on his roadster.... hes put 70,000 miles on the car with a couple different sets on it.... Tey actually have a higher load rating the the 145r 15 on the front of my car.... dont listen to the "The sky is falling group" motorcycle tires are fine
