Anyone no what radial tire I should be looking at to replace a firestone Champion 600 16 in a white wall? Sent from my iPhone using H.A.M.B.
whats wrong with another 6.00 16? you could use the bias look radial tires they make now, but no off the shelf radial will look like a 6.00 16 white wall. period
Hi. Also remember that if you use the modern radial replacement size you will be going to a wider tire and without power steering it will be harder to turn front wheels without some movement forward. For my 46 Chevy coup I used the Coker 600R 16 fronts and 700R 16 rears. For my 50 Plymouth Deluxe I used 670R 15's to replace 670 15 bias. I have had no problem with either of these bias look alike's from Coker. Jimmie
$$$$big bucks up here in Canada. But aguess u got to pay the piper Sent from my iPhone using H.A.M.B.
To actually answer the OP's question, I refer to the Coker website. The first selection is a 600 16 bias The second selection is the 600 R16 and is as close as Coker makes
