Technical Tire Fitment & a '32 Sedan
Discussion in 'The Hokey Ass Message Board' started by tjm73, Feb 25, 2024.
  1. tjm73
    tjm73
    Stock early style axle with juice brakes.
  2. alchemy
    alchemy
    The narrowest of the banjo rears. You can use my examples when you are judging offsets.
  3. tjm73
    tjm73
    Do you happen to know the width with juice brakes by chance? I've looked online but have found very little except for the chart from hot rod works.
  4. alchemy
    alchemy
    I don’t think they add much if any width.
  5. 19Eddy30
    19Eddy30
    from VA
    The Egg @ time with 40 juice , friction shocks , with stock 32 axel & stock 32 rear spring & 4 drop on front , 16 all the way around
    Just Gary likes this.
  6. tjm73
    tjm73
    On your picture running the steel wheels and bias plys, what size wheels and tires were you running?
  7. 19Eddy30
    19Eddy30
    from VA
    """Not"" Bias Plys
    Radial , front where from Coker's
    where expensive, then found alternates that looked close to the same from electric car Side walls said Electric,
    Bridgestone,, Here on HAMB say discontinue now
  8. alchemy
    alchemy
    When I used steel wheels they were 48’s on the rear, 4.5” wide with 7.00x16 Firestones. The front was 40’s that are 4” wide, with 5.50x16 Firestones.
