Technical Timing marks
Discussion in 'The Hokey Ass Message Board' started by blackanblue, Nov 11, 2015.
  1. blackanblue
    blackanblue
    Does anybody have any tips or tricks for making timing marks more visible using a induction timing light my eyes arnt as good as they used to, come to think about it they were never that great to start with. Thanks in advance..
  2. falcongeorge
    falcongeorge
    from BC
    Rub the mark with white chalk.
  3. Mr48chev
    I've done that and have cleaned and painted the area next to the mark either black or white and painted the mark the opposite color and then cleaned up the timing tab to see the numbers or the raised numbers on some timing covers. on ones that are painted orange or a light color I usually just clean them and use a sharpie on the mark.
  4. squirrel
    sharpie and chalk....make a white chalk mark on a black background
    falcongeorge likes this.
  5. Truck64
    Truck64
    from Ioway
    Chalk will work, a china marker seems to last longer. A timing tape is fluorescent and works well for tired eyes. ImageUploadedByH.A.M.B.1447275653.679398.jpg
  6. stimpy
    stimpy
    send it to a kid with better eye sight ... :oops:
    I clean the dampner up and use florescent chalks the yellow ones light up real bright ,
    but if the dampner/cover is off the car I clean them up , paint them flat black and then use some acrylic uv white paint (expensive 14 bucks for 8 oz) in the notch or do a wipe over the scale and numbers then clear coat it . stuff makes the numbers /scale pop out at you .
  7. falcongeorge
    falcongeorge
    from BC
    If it has a tape or degreed balancer, I usually cut the tab down to a point centered on the zero mark as well. makes it easier to see what the hell you are doing.
  8. evintho
    evintho
    White Testors model paint and accompanying brush.
  9. 2OLD2FAST
    2OLD2FAST
    from illinois
    Blue fine line masking tape works for me ..
    dave
  10. mgtstumpy
    mgtstumpy
    I put this on mine;):D
  11. Before you go to all the trouble of marking it, make sure the 0 is at TDC.......
  12. chargin03
    chargin03
    I use white out works great.
  13. blackanblue
    blackanblue
    No degree tape and it runs good I just want to conferm tweek timing cause I just cant leave things alone I like the whiteout idea thanks chargin03 i'll give it a shot...
  14. squirrel
    I thought whiteout went away with the typewriter...but hopefully I'm wrong.
  15. stimpy
    stimpy
    still find it at the office supply places , right next to the blonde monitor glass cleaner ...
  16. sawbuck
    sawbuck
    from 06492 ct
    junk yard yellow paint marker....shake it and mark it...lasts for years and you can see it....
  17. Capt Crash
    Capt Crash
    from Colorado
    X2
  18. 1oldtimer
    1oldtimer
    I thought whiteout was the universal engine marker :).
