Tight Fit- What Oil Fliter SBF in 50 Ford ?
Discussion in 'The Hokey Ass Message Board' started by fordstandard, Dec 3, 2011.
  1. Guys --what oil fliter do you use in your swap?
    Mine is very tight fit --must be a better way
  2. RDAH
    RDAH
    from NL, WI
    If the short one for a Dodge does'nt work, for sure an adapter from Summit will mount to the block & you can swivel it foward or down or any way you want it.
  3. flatheadpete
    flatheadpete
    from Burton, MI
    Don't remember what AC filter I use. I'll check in a bit.
  4. Doraville
    Doraville
    from Georgia
    I have a 302 in my '52 Ford F1. I used one of those remote filter mount kits to move my filter up onto the fender well. Otherwise, I would have had to use a tiny oil filter, which I didn't want to do.
    -DV
  5. Phil1934
    Phil1934
  6. Jalopy Joker
    Jalopy Joker
    I have a remote oil filter set up with '69 302 in '51 Ford because there is no clearance to run adapters like the 90degree, etc. but, after looking at link Phil1934 posted will go to NAPA and try a super short filter, plus get a free calendar. Thanks
  7. chopper cliff
    chopper cliff
    from lodi ca
    51068 Wix or Napa1068, 1/2 quart for Ford, works on my 28 next to steering box no problems, running a 302
  8. Ole don
    Ole don
    Motorcraft FL400 is a smaller diameter shorter filter for some applications, and a full diameter short filter was used on Thunderbird Turbo coups in the late 80's.
  9. TinShed
    TinShed
    I did not know the 400 worked? It is way smaller diameter and a bit shorther but the FL300 is the same filter just 1.7" shorter. I had to run that filter on my 48F1
  10. WE always used an oil filter for a 79 dodge pickup [2 wheel drive] with a 318 engine. Very short with correct dimensions to fit ford engines. forget the part number.
  11. Cerberus
    Cerberus
    Had the same issue with the Ford 302 in my avatar. The oil filter hit the frame. Then, at O'rielly's, I found FRAM PH43 for a Ford 302. Only 3 1/2" long...the length of a business card. Problem solved.
  12. George
    George
    I use Wix instead of Fram, but here's some comments. If the standard PH8A is too long, the (Mopar standard) FRAM PH43 is a bit shorter. The PH16 is shorter still(used on 351W Police Interceptor with oil cooler). The Wix 51335(NAPA1335) is about 2" long. Reportedly the Wix 51311 is a little longer that the 51335.
  13. Yes, the FL400 (motorcraft P/N) has the same thread and seal diam as the larger FL1A or PH8a. FL400 is just a bit larger diam then the seal surface. My wife's 2008 Ford Edge uses that FL400 and I found out about the thread and seal diam when searching for a larger filter, but there really is no room for any larger diam or length.
  14. A Boner
    A Boner
    Volvo....don't ask me what year though.
  15. aircoup
    aircoup
    a 1987 harley fxr oil filter works just fine , and its short '
  16. RidgeRunner
    RidgeRunner
    from Western MA
    For a 90 degree adapter check older Ford Vans with a big six. My '71 with a 240 had one from the factory.
    Ed
  17. I use a small diameter/short oil filter for a Chrysler product. AC PF53, Motocraft FL793, etc.
  18. Jalopy Joker
    Jalopy Joker
    tried the NAPA 1068 and too long for my set up, need one about 3" long. will go back to NAPA and try again. did get my free calendar. anyone know of a link to a chart for oil filters that gives cross reference to multiple brands?
  19. Jalopy Joker
    Jalopy Joker
    never could find a very good cross reference site for oil filters. so, after searching around ended up getting a NAPA 1311 (Wix 51311) which has a height of 3.372" (stock app NAPA 1515 series height is 5.178") . Would have gone for the K&N filter as upgrade but, nut on end of housing made things too tight again. AC-Delco PF53 is a very common filter and used on Harley's too. Harley discussion sites have good info on this filter. hard to find dimensions on all filters I looked at. summitracing.com gives pretty good info. still concerned about having less oil in system. at some point will likely go back to a remote full size filter set up.
  20. Al Von
    Al Von
    +1 on the PH16. I had an '81 LTD police car with the 351W and oil cooler adapter. That filter fit perfect, and about 1/2 the length of the FL1A.
  21. Cerberus
    Cerberus
    George mentioned a PH16 used in the Police Interceptors is shorter. So, when I was in Orilley's yesterday, I took a look at it. It may work for you. It seems about 3" long. It is much shorter than the PH43 that finally worked for me. Check it out.
  22. aldixie
    aldixie
    I know an MG midget filter will fit but it's on the small size. I have had to use a remote oil filter kit on my 302 in my 40 Ford pickup.
  23. Mark T
    Mark T
    80's Ford Van with a 460 should have a swivel adapter so you can run a full size filter.
  24. 94hoghead
    94hoghead
    I use a Baldwin B34. Its about 3 3/4 inches long....
  25. Buddy Palumbo
    Buddy Palumbo
    I doubt any MG MIdget filter will fit , but most likely a later MGB filter ...
  26. dana barlow
    dana barlow
    from Miami Fla.
    1. Y-blocks
    I'd go with a remoto set up so I could have a full size filter that would also be EZ to get to.
  27. jtc1180
    jtc1180
    M/C FL300 or Trans-Dapt Remote kit.
  28. Hedders
    Hedders
    I am using a NAPA 1085 in my 49 business coupe with a 289 and c-4.
  29. svo
    svo
    Fl 300
