tierod end with hole for draglink
Discussion in 'The Hokey Ass Message Board' started by anteek, Nov 1, 2012.
  1. anteek
    anteek
    I just spent an hour on a search and struck out. What is the application of the RIGHT side tierod end that also has a tapered hole for the draglink? Speedway sells it but napa does if I can find the application. Any help so I can work on the project this weekend?
  2. Ford Bronco. The Wizzard
  3. i always thought it was from a Rambler
  4. 40FordGuy
    40FordGuy
    Were those also used when a steering damper (aka steering shock) was installed? I'm thinking possibly Jeep applications ?
    4TTRUK
  5. racemad55
    racemad55
    I'm thinking jeep also, I think pete & jakes sold them at one time.
  6. enjenjo
    enjenjo
    from swanton oh
    Manufacturer Part No: J0640178
    53 to 75 CJ5
    You have to reverse the taper to use with a drag link. The one Speedway sells has a taper on both sides.
  7. The Ford Bronco one don't need the taper changed.
  8. F&J
    F&J
    Do you know if the tie-rod thread size, and taper size is the same as the early Ford stuff like 40's Ford parts?
  9. anteek
    anteek
    The CJ5 one is the one I've used. Anyone have a parts store number;like a MOOG#?
  10. Yes it is. The Wizzard
