I bought this tie rod end for my hot rod and it is split where the yellow mark is, from the hole and lengthwise toward the outer end. Anyone else experience this? When they first started to introduce these to hot rodders, I believe they were from some AMC car. Anyone know what they may have been from? Maybe these hot rod ones are aftermarket and are foreign made, hense the crack. Thanks
Could it be a superficial fab line? I have seen that before, if so, many of them can be sanded/ground away and dye checked.
They are a stock item on most 45/71 Jeep C-J with 4 cylinders . This link just tells what they fit. https://www.quadratec.com/products/918045_02.htm I have never heard of one cracking like that and live in the big middle of hard core Jeep four wheeling territory where they beat those things (the Jeeps) to death. I'd go with what Joliet Jake suggested first. Smooth off that forging line and see if it is actually a crack. I looked and can't find a Moog part number for that unit. The 4x4 shops and Summit all sell the Omix-ADA and a cheaper Crown one.
While I’m not suggesting it is a good thing that Speedway sources some items from China do you honestly believe they’re unique? Let’s use So-Cal for an example, another big name in the industry that is steeped in history. Do you think nothing they market comes from China? It’s a different time in a different world.
Im afraid I have to agree with you on that.Unless you find oem parts from years ago theres a great chance it all comes from the other side of the world.
