Technical Three on the tree chevy tranny question
Discussion in 'Traditional Customs' started by gallogiro, Jul 21, 2014.
  1. gallogiro
    gallogiro
    does anyone know how to adjust the shifter on a 48 chevy? I paid to get the tranny rebuilt and installed it again but when i try to shift it will barely go into reverse, itll go into first and third gear just fine but not in first. baisically the top two gears it wont go into the reverse and second but the two bottom gears it will the first and third. it feels like it has to travel just a bit higher on the top two gears to shift into them but it wont. its a chevy fleetmaster 216 engine synchromesh 3 speed column shift transmission the original one. thanks guys
  2. Ulu
    Ulu
    from CenCal
    Sounds to me it does need a simple linkage adjustment, If I understand what you're saying.
    (I'm not certain I do exactly...)
    If it was working OK, then suddenly not working right, you might have collapsed a rubber trans or engine mount.
    If the engine or trans can move around just a trifle, it throws the linkage out of adjustment.
  3. jcmarz
    jcmarz
    from Chino, Ca
  4. I seem to recall a series of holes that a bolt or dowel had to be run threw to align the linkage.. Does that sound familiar?
    Posted using my chicken and 2 cigs
  5. Ulu
    Ulu
    from CenCal
    If you disconnect the linkage at the trans arms, can you shift the gears normally from the trans arms, and feel them "click" into place?
    If not the trans might have a worn/bent shift fork.
  6. Ulu
    Ulu
    from CenCal
    Sounds like my Ford.
  7. their is a hole in the 2 levers in engine compartment to line up shifter. use a drill bit or bolt to line them up and adjust rods going to transmission arms.
  8. gallogiro
    gallogiro
    thanks for all the info guys, I knew Id find the answer here like I have for all the other questions ive posted in the past. well you guys helped, I got the links and levers adjusted, tomorrow I test drive after I set the distributor and timing hopefully I got the problem fixed. if not ill post a video of exactly what its doing wrong so you guys can see and hear the problem. but hopefully what you guys had me do fixed it thanks again if so =)
  9. Rusty O'Toole
    Rusty O'Toole
    There should be an adjustment on the rods under the car. The usual procedure is to loosen or disconnect the adjusters, put the gearshift in neutral and the transmission in neutral then set the adjusters. The hole in the levers is to hold them in the correct position, which I think is neutral.
  10. VoodooTwin
    VoodooTwin
    from Noo Yawk
    This video might help: And check the bushings in your linkage to make sure there isn't excessive slop. That can cause it to hang up or be hard to shift. Now for our movie:
  11. Most of you guys that replied to this thread failed to remember that he is working on an early chev WHICH IS A "SELECTOR" type tranny..One arm shifts all the gears with the selector arm selecting which to shift...
  12. 302GMC
    302GMC
    from Idaho
    You mentioned "links" ... is the vacuum shift stuff still there ?
