Thread pitch for holes in 61 283 balancer?
Discussion in 'The Hokey Ass Message Board' started by rainh8r, Oct 15, 2009.
  1. rainh8r
    rainh8r
    I need to pull the balancer/hub off a stock 61 283 crank that has a couple of threaded holes in it. Since the holes are rusty, I want run a tap down them but I can't see what thread they are (NC or NF), and neither thread bolt (3/8) will start because of the rust. Anyone know what thread the holes are? I'd like to use the right tap the first time. Thanks, Rob
  2. they are 3/8-24 NF
  3. rainh8r
    rainh8r
    Thanks, I'll tap it out tonight.
  4. Bruce Lancaster
    Bruce Lancaster
    Be cautious and run in a rifle cleaning brush so you can see the threads...I do know that the 350's are sometimes found with 3/6 coarse threads there, so I would carefully check early engines as well just in case.
  5. squirrel
    I haven't seen coarse threads in a small block damper, but there are millions I haven't worked on. big blocks have coarse threads
