this thread is only for the intelligent
Discussion in 'The Hokey Ass Message Board' started by onlychevrolets, Sep 14, 2009.
  1. onlychevrolets
    onlychevrolets
    u-joint problem
    shaft yoke measures 1.06 X 3.25
    pinion yoke 1.125 X 3.65
    what is the part number on the joint that fits this?
  2. Looks like you have to find another yoke for shaft or if your lucky there might be a pinion yoke you can swap to your rear.
  3. KCsledz
    KCsledz
    woops! not intelligent enough for this one!
  4. Find a yoke from a drive shaft that matches yoke on pinion...measure, cut , weld etc.
  5. skajaquada
    skajaquada
    from SLC Utard
    call any parts store that carries SKF products and find someone who knows how to operate a book. tell them to look in the back of the SKF book and if they can read, they can tell you the part number...long shot, i know, but the info is in there.
  6. garvinzoom
    garvinzoom
    I thought you chevy guys already knew everything.....
  7. squirrel
    are you sure it's not 1.06" x 3.25"?
  8. onlychevrolets
    onlychevrolets
    It is ...my f-up
  9. onlychevrolets
    onlychevrolets
    we do it's a Ford drive shaft.
  10. Take both yokes to a place that sells drive line parts for big trucks. Look for a big Spicer sign on the wall outside, lol. Go in, find the oldest counter man there and say, "I need a u-joint to mate this to this." If such an animal exists you should walk out with one in your hand, if he aint got it it don't exist. It's always worked for me.
  11. Imperial Kustom
    Imperial Kustom
    Call the local driveline shop. There is a very common conversion joint for this.
  12. squirrel
    Since I caught your fuckup, am I qualified to try to answer the question?
  13. #### Damn might want to rename the thread !! Sorry !!! >>>>.
  14. onlychevrolets
    onlychevrolets
    OK Squirrel...let fly....
  15. onlychevrolets
    onlychevrolets
    Righty -o there SAUSAGE guy.
  16. onlychevrolets
    onlychevrolets
    From what I can find a 434 will do it...is that the number you found?
  17. squirrel
    That 3.65" dimension...that's not where the snap ring fits is it?
  18. onlychevrolets
    onlychevrolets
    no thats overall...
  19. i think Precision # 372 should do it
  20. #### That would be SAUSAGE KING !!! >>>>.
  21. onlychevrolets
    onlychevrolets
    I got it...its a 434 precision ...thanks for all your help ...even you SAUSAGE KING :)
  22. How about a Precision #447.............combination inside clip old GM and outside clip GM.
  23. squirrel
    THat was a hint to you to measure where the snap ring fits, that's the dimension the books use
  24. Funny; I opened this Thread this morning and thought "This Guy don't know what he's talking about" The numbers just didn't work. I kept my mouth shut in fear of sounding un-intelligent. My mistake I guess. Good call Squirrel, glad you got his problem solved. We are after all here to help.
    The Wizzard
  25. What the heck does it take to qualify around here?
    Not smart enough.
    Not experienced enough.
    Not cool enough.
    Not trad enough.
    But not too far from the driveline shop....
  26. Spicer 5-3022x. Inside snap ring GM on one side, 2 9/16" between ears, 1 1/8" caps. Outside snap ring on the caps wthat measure 1 1/16 , touch under 3 1/2" outside yoke ear to outside yoke ear.
  27. Or because I'm too damn late again, what only gave is a u-joint for the rear of a 1985 Ford 1/2 ton pickup driveshaft.
  28. Rootie Kazoootie
    Rootie Kazoootie
    from Colorado
    Intelligent ? Maybe I'm missing something, but 2-3 hrs. to get a part # when a 5-10 min. phone call to the driveline shop/parts store could have done it? Maybe ignorance really is bliss. :confused:
  29. squirrel
    or just a parts store.
  30. scottybaccus
    scottybaccus
    all hail furry rodent in the pink chevrolet!
