Event Coverage The XO/PP Virginia HAMB Special Is Ready for Bonneville!
Discussion in 'The Hokey Ass Message Board' started by TomT, Aug 4, 2018.
  1. Really kind of Erie this morning, like a bit if a ghost town affect - I can probably count on one hand how many runs have been done this am ....
    John just got here so it's tine to get to work
    Stogy, loudbang, MP&C and 4 others like this.
  2. Tim
    Tim
    from Raytown Mo
    Man, so cool :)
  3. greybeard360
    greybeard360
    Close ratio 4 speed .... Keep the motor in the power band between shifts. A T5 is pretty wide ratio and 5 th gear will lug it pretty hard. You will probably still have to push it to get it rolling but you guys have that part down by now.
  4. Scott_Rod
    Scott_Rod
    Some random transmission gear info. It’s from the inter web so it must be true.
    Powerglide. 1.76 1st, 1.00 2nd gear
    Th350. 2.52 1st, 1.72 2nd, 1.00 3rd
    Th400. 2.48 1st, 1.48 2nd, 1.00 3rd
    Most of the Chevy automatics have a similar drop going into high gear. The th400 has the tightest shift to high.
    A short tail shaft TH 400 is the same length as a powerglide, but uses a 32spline yoke instead of the 27 spline of the PG and th350.
    loudbang, Stogy and chryslerfan55 like this.
  5. GMC BUBBA
    GMC BUBBA
    I feel as if the overall air density should be taken into consideration . 100 degrees at the Salt the air density is the same as 7000 feet during the day etc. Thats a 20% reduction in everything compared to sea level ?? 6000 rpm now equals 4800 ?? And this even changes during the day. Just a thought ??
  6. @GMC BUBBA landracing.com is broadcasting this information every 10-20 minutes. I'm sure John has it covered!
    loudbang and Stogy like this.
  7. Working on the tranny bushing problem, the tailshaft was removed, yoke cleaned up, new bushing installed, and sanded down for enough clearance so fluid can ride between the two ....
    We still have not done a compression test ....
  8. old flopper
    old flopper
    Have you heard if there is a minimum speed they have to run to get license and get off short 2 mile rookie course and on to 3 mile competitive course? That would help by giving another mile for acceleration.
    Or just get some nitro from Thompson, that take care of that 2 speed transmission problem. :D
  9. saltflats
    saltflats
    from Missouri
    Looks like a fair amount of weight on that driveshaft.
    You may want to think about a new one when you get home.
  10. winduptoy
    winduptoy
    Not to distract from the focus of this thread, but it is speed week and..... IMG_20180813_135206661.jpg IMG_20180813_122555661.jpg
    Sent from my XT1254 using The H.A.M.B. mobile app
  11. winduptoy
    winduptoy
  12. Danny Thompson's new record holder @448 ....
  13. ...heard that Speed Demon went 452 and change in B/BFS...fastest MPH so far!
    chryslerfan55, loudbang and Stogy like this.
  14. Stogy
    Stogy
    That fella Danny is quite the inspiration. Congratulations to Him and his Team...
    Thanks to all keeping us on the edge of Land Speed exhilaration...I mean acceleration...:D...hey...I'm wearing my 640 shirt today...Go Team 640 Go...;)
  15. winduptoy
    winduptoy
  16. chryslerfan55, loudbang and Stogy like this.
  17. oj
    oj
    Air is 7000'?! Goddamn, theres barely enough oxygen for the driver let alone an engine! What are the actual numbers? Thats a killer.
  18. winduptoy
    winduptoy
  19. winduptoy
    winduptoy
  20. We are ready for another attempt tomorrow. Cyl 4 is ok - comp was good, no cyl wall scores as we checked it with a borescope we rented.
    Tire size is smaller, we adjusted the throttle, aired up the tires to 75 lbs as Goodyear stopped by today, and the driveshaft/pg tailshaft is all buttoned up.
    Fingers crossed ....
  21. Go get’em boys!!!!
  22. jimmy six
    jimmy six
    Bonneville or land speed always has a learning curve. Trouble is its a learning curve every year. We choose to do things in building we believe will work and be the best choice. Some times they work, don't, or break in ways we can never anticipate. Not giving up is the key and we are seeing it right before our eyes. It is not Friday yet..go get 'um...guys.
  23. RidgeRunner
    RidgeRunner
    from Western MA
    Says it all well worded in a nut shell right there!
    Big +1 on the go get 'um...guys!
    Ed
  24. VeryTangled
    VeryTangled
    from Outside DC
    7:45 eastern on the FordBarn from TomT:
    We are ready to make another attempt tomorrow - we've made sone changes and we are feeling pretty good about things right now. If she stays together and all the starts align, we hope to post good news .....
  25. GO, GO, GO. Have fun and be careful.
  26. VeryTangled
    VeryTangled
    from Outside DC
    Speaking as a noob here. I hope they can get a couple of strong runs maybe 2-3 runs from now. Keep all the parts on the truck and inch it up as long as everything stays connected. EDIT TO ADD: Parts left on the track surely will not be hepful.
  27. Stogy
    Stogy
    Suns going down but the thumbs are up...
    Go Team 640 Go!!!
  28. Tom Samson
    Tom Samson
    chryslerfan55, catdad49 and loudbang like this.
  29. The 640 is prepped and ready for an early morning run tomorrow. It’s suppose to be a little cooler so we changed to a thinner fluid in the air density compensator to reduce the annular drag coefficient on the super wienel drive gear. That outta get ‘er rollin sweet!
    We managed to clear out a few grammeters of NaCl in the cross shaft cooling jet for the turbo encabulator as well. The idea to check that came when the guys pitted next to us had to tow back. Seems their jet got plugged, flux pulses reverberated and they blew a johnson rod.
    63fdsnr, MP&C, dirty old man and 17 others like this.
