The Wheel & Tire Thread - FIND THE RIGHT COMBINATION FOR YOUR HOT ROD!
Discussion in 'The Hokey Ass Message Board' started by Florian, May 21, 2009.
  1. Florian
    Florian
    The idea is simple: Post a pic, or two of your Hot Rod and tell us the wheel size(s) & width(s) and the tire size(s) & brand(s) (and maybe the overall diameter) you´re sporting.
    This could be a very helpfull thread for everyone searching for the right wheel and tire combo for his project! You can compare different combinations others drive around and can decide which one you like the most!
    This thread can save you a lot of time chasing the perfect stance and it may even save you a lot of cash by bewaring you of wrong buys!
    So, do the HAMB and its members a favor and post your little secret :D
    Thank you so very much,
    Florian.
  2. thepolecat
    thepolecat
    1. S.F.C.C.
    very nice idea
  3. Drive Em
    Drive Em
    -Rear-8.20-15 Firestone dirt track tires on back on a 15" x 6" "flipped" around Chrysler Cordoba wheels. App. 30" tall.
    -Front-5.00-16 Firestone ribbed tires on 16" x 4" wide 5 Ford wheels. App 26" tall.
  4. 20th Century Chevy
    20th Century Chevy
    15 X 8.5 American racing torque thrust orginals...polished......Hurst cheater slicks....28 X 8.20......
  5. 1956 Thunderbird--6.00 x 15 Firestone's on 15x5 stock steelies
    1960 F-100 235/75r15 all around on 15 x 5 ford steelies:
    Same truck, 15 years ago. Stock height, 15 x 7 smoothies, 235/75r15 all around:
  6. I would be interested in seeing a picture of a 285/70r15 BFG/Coker radial on an 8" and/or 10" wheel, if anyone has that set-up?
    That's what I am pondering in the rear of my '60 above...hard to put any power down (at any speed) with the 500" Caddy...
    BRT
  7. yankbuilt
    yankbuilt
    Front 195/75/14 6'' wheel, Rear 235/75/15 8'' wheel
  8. JeffreyJames
    JeffreyJames
    from SUGAR CITY
  9. chop&drop
    chop&drop
    Front: 165SR-15 on 15X5's Rears: 245-65-17 on 17X8's all American TTO's
  10. bsmdeuce
    bsmdeuce
    My tires are 450/475 16 front and 750 16 rear. Both tires are firestones that I bought from coker. Brock
  11. Drive Em
    Drive Em
    Here is a 285-70-15 BFG on a 10" wheel on my '64 Galaxie:
    Here is a 285-70-15 on an 8 1/2" wheel:
  12. Awesome! THANKS!
  13. roadsterpilot
    roadsterpilot
    I have 265/75/15 on a 15x7 rim(black roadster)
    the tan roadster has 285/70/15 on 15x8 1/2
    both have 145/15 on the front...............Hope this helps.
    RP.
  14. Von Rigg Fink
    Von Rigg Fink
    from Garage
    I know its not done yet but
    Wheels : American Racing Vintage 15x4.5 fronts 15x 7 out back 3.5" BS
    Tire sizes Front 165/80R15
    Rear P235/75R 15
    theres some better shots than this of it in my albums, just couldnt figure out how to load the picture instead of the url
  15. Ron Mayes
    Ron Mayes
    that's one Bad Ass ride
  16. [​IMG]
    7.50x16 and 5.25x16
  17. 19Fordy
    19Fordy
    FRONT:5:60 x15 Coker (2 3/4"WW), Tire dia. 25.88 on 15 x 5 1/2" early Ford truck rims(Total rim width of 6 1/2"); 3 3/4 in. backspacing. Stock drums; Posie reversed eye spring; Magnum 4 " dropped axle ( 3/4 in narrower than stock axle), Magnum dropped steering arms; stock sway bar and perch bolts and unsplit wishbones; 8BA flathead. Bolt pattern is 5x 51/2. REAR: 7:60x15 Coker BF Goodrich (3 3/8" WW); 28.66 dia tire on SOLIDS 15 x 6 rims (Total width of 7"); 4 in. backspace; Stock 40 rear,spring and shackles. Bolt pattern is 5 x 5 1/2". Front grille chin pan clears ground by 4 1/8 in. This set up dropped the front end a total of 8 3/4 in after "settling". (Just pretend the wheels arn't red.)
  18. 29nash
    29nash
    from colorado
    F. 500x20 Excelsior
    R. 650x20 Firestone 33 inch tall
  19. Harms Way
    Harms Way
    8.20 X 15 Rear, 5.60 X 15 Front
    This one was 235-70-15 rear and 165-75-15 front (different car)
    H-70-15 Rear,... F-70-14 Front
    235-75-15 Rear and 205-75-15 Front
    7.50-15 Rear,... 6.70-15 Front
