The Ultimate 235 Hop up Thread.......
Discussion in 'The Hokey Ass Message Board' started by SLAMIT, Jan 20, 2011.
  1. hotdamn
    hotdamn
    awesome! I love old dailys!
  2. Torkwrench
    Torkwrench
    I'm to the point of buying an intake for my 235. The choice is between an Offy 3x1 or an Offy 2x1.
    The engine is a 1955 235 bored .060, with an Isky E2 cam, and a 1961 848 head that has been ported & polished. The dist. is a Mallory Unilite and it has Clifford tube headers.
    My question is about carb/intake/air cleaner clearance. The engine is going in a 1955 2nd series pickup with stock motor mounts and a stick shift trans.
    Does anyone definitely know if the Offy 3x1 intake with Roch, 1 bc carbs will clear the firewall and hood? I have searched many books, catalogs and threads here on The HAMB. Some say that it will clear, some say it will not. Does anyone know about this specific application?
    Thanks for all replys.
  3. Snarl
    Snarl
    Well, the rear carb is directly inline with the rear port, so if you have the engine in the truck, take a carb and place it in that position and see what you have for space.
    I had to cut the firewall in my '53 truck for tripower.
  4. Sir X Loin
    Sir X Loin
  5. 53chevtrev
    53chevtrev
    from Langley BC
  6. ftwkustom
    ftwkustom
    from michigan
  7. ftwkustom
    ftwkustom
    from michigan
    AMW likes this.
  8. King Karl
    King Karl
    from N.C.
    Bump in hopes of bringing it back from the dead.
  9. King Karl
    King Karl
    from N.C.
    OK, since there are no takers on general info I do have a specific question.
    I've seen several references (different websites) to a 261 build that used GMC rods and Buick pistons. With only a mention of the build, there were no supporting facts or numbers.
    Has anyone here used the combo and what are the benefits of doing so?
    I've just torn down a 261 that I had planned on doing a fairly stock build on but was given a set of GMC rods that could possibly be used if worth the trouble. Any experienced advise would be appreciated.
    Any other tips appreciated as well.
  10. Dyno Dave
    Dyno Dave
    Try the Inliners site. Thinking Tom Langdan was the creator of this combination, there may be something on his website. dyno dave
  11. King Karl
    King Karl
    from N.C.
    I called and spoke to Tom on this after that post since there is only mention of the possibility on any site you go to. (Even inliners)
    I don't have all of the measurements and part numbers in front of me at the moment but you have to use GM rods from a 302. They are the only ones that will work with this combo. They will need to be narrowed a bit. Also, the rods are designed for floating pin but the Buick pistons are press fit so you have to shim the rods before pressing the Pistons.
    I have all the particulars if anyone else is thinking of doing this. My poisons and rods are done, I just have to get everything together and balanced. Hoping to have it all back together before next spring.
  12. SLAMIT
    SLAMIT
    Cool info! and it is neat to see this thread slowly come back to life. I had really forgot I started it and just went back through it. Good stuff in here. I haven't touched my car since I started it which is sad to say really however My family is well taken care of and I have been doing a bunch of work on other peoples cars so Im not dead. just my car hahaha. SOMEDAY!
  13. 49fastback
    49fastback
    from Alabama
    I'll keep the thread alive - anybody have a line on good machine shops in the southeast that have the knowledge and "tricks" to handle a 235 with confidence? Wonder how many would look crazy at me if I walked in and asked about a torque plate for my 235 build?
  14. RATRODCHEVY
    RATRODCHEVY
    RATRODCHEVY
    from The Motor City
    If you haven't asked about Stovebolt rebuilders on the Chevy Talk or Stovebolt websites, you might want to.
  15. Cosmo49
    Cosmo49
    My truck is on the bottom of page 4, last December I went over 100,000 miles on my dd/only vehicle. Same engine, a '56 235.
  16. Rusty Heaps
    Rusty Heaps
    great to see this thread resurrected
  17. Any info on what works to build a mild 235? Machine work intakes carbs?
  18. Aeroman
    Aeroman
    I'm building a mild 261cui.
    1. Nicson 216 intake, dual carb
    2. Patrick's mid range cam
    3. 1953-1955 Corvette exhaust manifold
    4. Zenith carbs
    Sent from my SM-G925V using Tapatalk
    AMW likes this.
  19. What's the difference heard ppl say go carter yf or w-1?
  20. Here the best answers I have received
    ( mill head .100, sink valves and do full comp. valve job, bore no more than .060, new mech. Lifters, ground stock cam, 2-3 pot intake, split manifolds, carter carbs) am I missing anything or things that should be done differently really want this to be dialed in and have a fun street I6
  21. SlickT
    SlickT
    from Tn
    1. A-D Truckers
    2. Inline motors
    Good thread lots of info
  22. Jebo
    Jebo
    I ordered a camshaft and other goodies from Patrick's 6 months ago. Still no cam. Who knows what the best rumpty cam is and who sells it? Thanks jebo
  23. RATRODCHEVY
    RATRODCHEVY
    Call Tom Langdon at Stovebolt or go to http://www.langdonsstovebolt.com/ he has a lot of good info on his site. I’m pleased with the “BullDog” cam i got from him in my 261.
    Jebo likes this.
  24. Dyno Dave
    Dyno Dave
    TECH QUESTION Have a '54 Bel Air 2dr. post, am having a .040 over 261, milled head, decked block being built. It has a Corvette 3 sidedrafts intake, long tube headers, and a J.Hunt mag. Undecided on cam grind. Running a CR 5speed, S-10 4.10 ratio rear end. It's a driver... not a drag car. Finally, to the question??? Should I have the flywheel lightned, if so, HOW MUCH? thanks, dyno dave
  25. Kerrynzl
    Kerrynzl
    What??? How do you use a torque plate to deck the block?
  26. I am building a 261 for a late fifties early sixties style outlaw style modified stock car.
    Machine work by B & G engine service @BnG Engine
    .040" over bore
    848 head ported and polished 74.7cc after the .052 surface.
    rods resized and machined for A.R.P. Ford 460 bolts
    [​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG]
    And now the hop up goodies dumbied up-
    N.O.S. SCHIEFER aluminum flywheel
    Dyno Dave likes this.
  27. jersey greaser
    jersey greaser
    sub'ed
    thanks for the return of grand memories guys,
    if any one from jersey and island dragway remember a 54 belair named the stove bolt. i'm one of the team and george is still playing around there .
  28. SlowandLow51
    SlowandLow51
    Thinking of doing a build that is similar to the May 1955 Chevy 261 Build. I have most of the parts now.
    McGurk # 18 Camshaft
    Grant Rings
    McGurk Pushrods
    Jahns 3 7/8 Pistons
    McGurk Triple Intake
    Anyone have any thoughts. I have a 261 that is going in my 47 Chevy business coupe, but if I build another I was thinking of duplicating the 1955 Build.
