Projects The Thrifty T build!
Discussion in 'Traditional Hot Rods' started by sodakmini, Jun 18, 2015.
  1. sodakmini
    sodakmini
    from Pierre, SD
    Thanks bud!
  2. Mike Colemire
    Mike Colemire
    Those dang dents on the doors at the top around that belt line are a pain to do anything with. I'm not the greatest body man by any means but I had a heck of a time on my 28. This is going to make a nice little hot rod, great work.
  3. sodakmini
    sodakmini
    from Pierre, SD
    [​IMG][​IMG][​IMG][​IMG]
    Cleaned the garage, got some motivation, started in on some sheet metal work I’ve been dreading and had a really good time messing with it. Ready to keep working my way around. While still putting off my passenger door.
  4. sodakmini
    sodakmini
    from Pierre, SD
    Screwed up my patch panel. And had some damage I didn’t realize or understand how to fix. So started to fix. Cut the seam to make crap work together. Made it worse. Found some good help. He asked that I removed the rust. I’m about half done He is going to run the planishing hammer around the body a few times. Should make a big difference [​IMG][​IMG][​IMG]
    dana barlow and volvobrynk like this.
  5. sodakmini
    sodakmini
    from Pierre, SD
    Nice fella in the photoshop thread did this for me. [​IMG]
  6. Top looks interesting; but you need to work some crown into it; primarily side to side; but a little for and aft. Think about losing the visor; or if not, maybe look at a '28-'29 painted visor.
  7. sodakmini
    sodakmini
    from Pierre, SD
    Top was photoshopped as well. Don’t think it’s going to have a visor. Top will be flat wood covered in black or white tuck n roll.
  8. Sure; but the point I was making is that a T roof that is actually flat, will end up looking concave, like a bowl, unless you build some crown into it.
  9. rusty rocket
    rusty rocket
    The photoshop should get you jazzed up.
    sodakmini likes this.
  10. Got rid of the visor....
  11. sodakmini
    sodakmini
    from Pierre, SD
    Heck yea. Love the photoshop, thanks moose! I’m sure I will make some kind of supports to keep it flat. I don’t want it to bow up either
  12. sodakmini
    sodakmini
    from Pierre, SD
    Stripping this thing 1” at a time. Ugh
    chryslerfan55 and volvobrynk like this.
  13. sodakmini
    sodakmini
    from Pierre, SD
    Have removed all the rust off the main rear panels with a hamburger wheel and started running 80 grit over it with my crappy DA, wiping down with thinner. Should make straightening these panels a bit easier. Going to pull the rear window and panel under it, out of the car after some bracing, to make panel working a bit easier [​IMG][​IMG][​IMG]
  14. sodakmini
    sodakmini
    from Pierre, SD
    Have removed all the rust off the main rear panels with a hamburger wheel and started running 80 grit over it with my crappy DA, then wiped down with thinner till it’s clean. Got a good buddy with a planishing hammer, going to work over the panels for me. Can’t wait to see the end product.
    [​IMG][​IMG][​IMG]
  15. rusty rocket
    rusty rocket
    Looks good man! Since your so good at rust removal you can come over and clean up the single seater. Its small it should'nt take you to long.;)
  16. sodakmini
    sodakmini
    from Pierre, SD
    Good idea. I will send Hayden right over
  17. rusty rocket
    rusty rocket
    Great!!!! I can give him a few model cars kits for payment!
  18. sodakmini
    sodakmini
    from Pierre, SD
    Not much of an update. Had a buddy over to do some panel massaging and bumping. Had to dissect it a bit. Have a good plan to fix my screw ups.
  19. A Boner
    A Boner
    That opening looks like a good place to install a rear door!
    Tman and sodakmini like this.
  20. VA HAMB
    VA HAMB
    That's what I was thinking! :)
    rmorris and sodakmini like this.
  21. VA HAMB
    VA HAMB
    Cool build!!!
  22. sodakmini
    sodakmini
    from Pierre, SD
    Thank you
  23. sodakmini
    sodakmini
    from Pierre, SD
    Buddy came over again tonight. Doesn’t look like much but was a huge step forward fixing one of my big screw ups. Few more steps and will really have something. He’s a heck of a talent, really trying to learn something. [​IMG][​IMG]
  24. rusty rocket
    rusty rocket
    Baby steps but your getting there
  25. touring20
    touring20
    Really nice proportions ! What kind of steering box are you useing ?
  26. sodakmini
    sodakmini
    from Pierre, SD
    Thank you. Reversed Corvair.
  27. Kirby50
    Kirby50
    from san diego
    Love this build!
  28. KandN Kustoms
    KandN Kustoms
    Hey man,
    You still plugging away at this?
    We miss your updates!
    Sent from my SM-G960U using The H.A.M.B. mobile app
    patmanta likes this.
  29. rusty rocket
    rusty rocket
    I think he fell off the side of the Earth. Haha!
  30. jim32
    jim32
    1. Hamb & Eggs
    Since you where all thinking I will ad something I saw yesterday.[​IMG]
