Projects The Thrifty T build!
Discussion in 'Traditional Hot Rods' started by sodakmini, Jun 18, 2015.
  1. sodakmini
    sodakmini
    Thanks for the heads up. I didn’t figure these shocks would do much. Will probably get something else in the future. (These were budget friendly). How would I add a steering damper to this setup? Or would it be easier to change to a more narrow front spring?
    dana barlow likes this.
  2. dana barlow
    dana barlow
    from Miami Fla.
    1. Y-blocks
    Spring wise yes,best is if spring with full running road Wt. lbs. on it,has shackels at 45*full loaded. So shorter spring maybe needed. In some case's the upper shackel mount can be move out more,but were that can't be done,then shorter spring,they can be found custom made. The old school way was to cut an weld dead center { this were the center is held inside spring center brecket anyway so dose not flex there or show,then place rest of leafs back/ if #2 leaf on top of longist leaf is now too long=it can be just grind ends nice to fit. Just some ideas if ya find its needed.
    alanp561 and sodakmini like this.
  3. Tri-Power
    Tri-Power
    from Memphis
    Steering damper won't control side to side movement in the front end. You should probably add a panhard bar to control lateral movement, AND a steering damper just because. I'm not convinced that the 3rd rear link is sufficient either. Both of my buggy sprung cars have front and rear panhard bars. I've had bushings fail on 2 of the bars and you know it immediately. The car feels squirrely as hell.
    alanp561 likes this.
  4. sodakmini
    sodakmini
    Well it’s painted and done far as I’m concerned right now. Will fix things as they appear. And if it does need a 4th link it will get one I suppose. I’ve had several 3 link rears without the leafs before and no issues. I don’t see how this is any different. But I appreciate the heads up and will pay attention to it.
  5. sodakmini
    sodakmini
    Time to make it look like a car again.
    kidcampbell71 and Beau like this.
  6. sodakmini
    sodakmini
    [​IMG][​IMG]
    Ugh. I love this thing
  7. rusty rocket
    rusty rocket
    Hey SUMBITCH, How come You didnt tell me you had a build thread going? I would have givin you shit since page ONE!!!!
    Greenblade and sodakmini like this.
  8. sodakmini
    sodakmini
    I’m a “closet” member.... ha
    Greenblade and kidcampbell71 like this.
  9. rusty rocket
    rusty rocket
    You know if you want me to help you have to give me more than an Hours notice!:)
  10. sodakmini
    sodakmini
    Will be a bit closer in a few months! Than I will just put up a cot for ya
    Greenblade likes this.
  11. sodakmini
    sodakmini
    Started playing with the new cluster. After a bit of cutting, I really dig it. Out of a ‘50 Nash
  12. rusty rocket
    rusty rocket
    Are you going to paint that thing Purple? Sorry that was low!!!
    sodakmini likes this.
  13. sodakmini
    sodakmini
    Good one. Ha. I may never watch football again
  14. rusty rocket
    rusty rocket
    Any progress on this thing?
  15. sodakmini
    sodakmini
    I put some parts inside it today.... garage is finally coming around. It’s turn is nearing.
  16. rusty rocket
    rusty rocket
    When did you move from Pierre? Heard you are in Rapid City now. Better change your profile;).
  17. sodakmini
    sodakmini
  18. sodakmini
    sodakmini
    Redid the bottom of the firewall with 16 gauge, finally finished my steering column, found a handy void in the column for a push button, drilled and tapped a set screw for it, made a firewall support for the column, then finished by attaching my deluxe banjo wheel. Turns smoothly lock to lock. Started tearing out the floor to go a little different route. [​IMG][​IMG][​IMG][​IMG]
  19. Dakota
    Dakota
    from Beulah, ND
    looking good.
  20. rusty rocket
    rusty rocket
    To bad we couldnt find any junk to buy this morning. I guess your getting some garage time.
  21. sodakmini
    sodakmini
    Next year Tim! Just came inside from grinding n welding. Making some headway on the floor
  22. sodakmini
    sodakmini
    [​IMG] Tore out the floor I built several years ago. And stated on this one today. Made a hammer form and recessed a access door for the master cyl. The old floor was only 22 gauge. This has more supports and is 16 gauge. Much much better
    patmanta, chryslerfan55, bct and 2 others like this.
  23. Mike Colemire
    Mike Colemire
    Really like your build, going to be following this.
  24. sodakmini
    sodakmini
    Thanks!
  25. Looks like you are all settled in now
  26. sodakmini
    sodakmini
    I should really take some more time for organizing the garage, but have serious hot rod fever going on. Ha
    chryslerfan55 and sko_ford like this.
  27. rusty rocket
    rusty rocket
  28. sodakmini
    sodakmini
    Got passenger side floor in. So much better. That other floor really sucked. Tore my new door apart. And mounted it with all my good hardware. Definitely fits better but is in pretty sad shape. Will need a lot more work. [​IMG][​IMG][​IMG]
  29. rusty rocket
    rusty rocket
    Floor looks great.
  30. sodakmini
    sodakmini
    Thanks bud!
