Technical The smallest physical dimension production V8?
Discussion in 'The Hokey Ass Message Board' started by BamaMav, Aug 28, 2020.
  1. BamaMav
    BamaMav
    from Berry, AL
    Going down the road the other day, doing what I do a lot of the time, thinking about building something after I get my Linc completed. Was sorta thinking about a 27 T roadster since the have a little more leg room than a 23 T, and you could get a stretched one for a little more. Then got to thinking about a power plant, it would be a light car, a 4 or a 6 would do fine, but we're hot rodders, so it had to be a V8, right? In keeping with the small and light theme, what V8?
    What was the smallest production V8 you might find in a junkyard? I would think the aluminum Buicks would probably be the lightest. But what would be the smallest, dimensions wise? And which one had the least displacement?
    This is all just theoretical, I don't know if I'll ever get to another one, but might be good info for somebody else that might be like me and think out of the box every once in a while. Something besides a SBC or flathead Ford.....
    studebakerjoe likes this.
  2. 57JoeFoMoPar
    57JoeFoMoPar
    221 SBF Windsor is pretty damn small.
    Deuces, alanp561 and loudbang like this.
  3. Paul
    Paul
    Editor
    Nads is using a 151 ci hemi in his T bucket..
    That's pretty small internally, don't know how big it is externally
  4. dana barlow
    dana barlow
    from Miami Fla.
    1. Y-blocks
    215 Buick v8,n Olds,are now Rover V8s
  5. lake_harley
    lake_harley
    Well, I can't get under 151 Cu. In., whatever engine that might be, but I have a 215 Olds in my '23 T roadster. I don't think physical size is much different than a SBC though. Since you mentioned the Buick version there was also one used by Pontiac (I never researched if that was the Buick or Olds version) and then Rover bought the whole she-bang.
    My T weighs in about 1350 or 1400# and with a few mild modifications it has the 215 should be good for about 160-180 HP. Pretty spirited little car. Too bad the Olds transmission is, well...not so great.
    Fun thing about the Olds engine is having people guess what it is.
    If I were building another T, whether it be a '23 or '27, I would seriously consider a 4.3 L Chevy V-6. The shorter length of it would be quite a benefit in my opinion.
    Lynn
    gnichols, banjeaux bob, OFT and 2 others like this.
  6. 1pickup
    1pickup
    60 hp flathead?
    55styleliner, LSGUN, Saxon and 12 others like this.
  7. blowby
    blowby
    from Nicasio Ca
    135 cubes, but alas, a flathead.
  8. swifty
    swifty
    That would be the 2.5 litre Daimler.
    I think it was in the 70's that Toyota produced a Hemi V8 which was used in large sedans which we never got here in Oz. I don't know their displacement but a local guy ran one in a T-bucket and was importing them from Japan and selling them locally. I think they were only made for a few years so may be hard to find one now.
    Ned Ludd, pitman, dana barlow and 2 others like this.
  9. 215 are pretty cool looking little motors..and the sand rail guys Hop em up...
  10. Bobby, don't rule out the flathead 60, it's a small V8 but with that it is also a small displacement engine. HRP
    Boneyard51 and warhorseracing like this.
  11. Tim
    Tim
    from KCMO
    V860
    Boneyard51 likes this.
  12. This is in a Hillman Husky/ Comer Cob van. Not sure if a V-8 60 on Simca Verdette, but the engine bay once housed a small 4 cylinder. JW
  13. BamaMav
    BamaMav
    from Berry, AL
    All good ideas, especially the little Hemi that Nads has, I remember the thread on his. I didn't think about the imports, they might have something, too. I was just thinking small size, light weight, maybe a 5 speed behind it, like an oversized go kart if you will.
    Gives me something to think about. Hoping to retire next year and work part time a while, know I'll be wanting something to build to take up some time, just don't want to get into anything big. Something small that I can source mostly used parts for and build on a budget {read dirt cheap}. I'm thinking something like stock A front end, 8.8 rear, small V8, maybe V6, 5 speed, fiberglass body on a kit style T frame. If it takes few years to come up with stuff, so be it, it's not going to be a rush job, if I even do it.
  14. pkhammer
    pkhammer
    I have a Flathead V8 60hp I'd sell. They are tiny. 136 whopping cubic inches.
  15. Just to compare, a Willys Jeep side valve is 134 ci and 63hp standard. JW
  16. Rusty O'Toole
    Rusty O'Toole
    Studebaker offered a 224 cu in V8 in 1954. It was the same size externally as other Stude V8s, or about the same size as a small block Chevy. The small Daimler is about the smallest you will find but good luck finding one. BMW had a small V8 of 2.6 to 3.2 liters 1951 - 65, then a 3 liter M60 in 1992.
    Your best bet would be a Rover 3.5, successor to the Buick, as far as availability goes. They are small and only weigh about 320 lbs.
    Then there are some lame-o American V8s from the 80s like the Chev 267, a lightened version of the Chevy small block. I think Pontiac made a 301 cu in light weight version of their V8.
    Ned Ludd likes this.
  17. mgtstumpy
    mgtstumpy
    Daimler Hemi 2.5lt (152ci) V8
    fredeuce, Ned Ludd, pitman and 6 others like this.
  18. lake_harley
    lake_harley
    Just out of curiosity I did a tiny bit of searching but didn't find any physical dimensions for a V-8 60. Anyone have the length, including all the front of the engine parts, width and weight? Basically, would a V-8 60 fit under the stock hood of a '24 or '27 Ford T without cutting into the firewall?
    Lynn
  19. pkhammer
    pkhammer
    23" from tip of fan blades to back of block. The cast on clutch housing adds another 4" but that is just down at the bell. It's about 16.5" wide. No idea of weight.
  20. lake_harley
    lake_harley
    Thanks, pkhammer! That's really compact! A quick search showed the length of the hood all the way back to '17 is 24 7/8" and the '26/'27 is a bit longer. Sounds to me like a full fendered T was built with a V-8 60 in mind.
    Crap....now I'm dreaming about "another" what-if project. I could never live long enough to build everything that I dream up.
    Lynn
    VANDENPLAS and pkhammer like this.
  21. Deuces
    Deuces
    Except for the 351.....
  22. pkhammer
    pkhammer
    Should fit a T to a T! Ba-dumm-ching.........(drum and symbol). :rolleyes:
    alanp561, VANDENPLAS and lake_harley like this.
  23. fiftyv8
    fiftyv8
    from CO & WA
    Am I missing the point of your question you pose.
    Do you actually mean the small size of the engine physically or by cubic inches or my interpretation was the smallest production numbers, meaning the least number of V8 engines made???
    lippy likes this.
  24. 1946caddy
    1946caddy
    from washington
  25. 5window
    5window
    I would really like to have an Olds/Buick 215. Back in 1963 my dad had a Jetfire-215 water injected turbo-that got 1 HP/cu in. That car would scoot. Unfortunately, the dealer couldn't keep the turbo running and he traded it in a year later. It cost $300 more than the carb version when he bought it and was worth $300 less when he sold it.
  26. BamaMav
    BamaMav
    from Berry, AL
    That's probably what I'm doing,too, but it keeps me out of trouble most of the time!
    I was wondering about physical size, it pretty much stands to reason that a small package would have less cubic inches. But there were some standard sized blocks with small cubic inch displacements, as per the 267 Chevy and 221 Ford mentioned above. Sorry if I wasn't clear.
    I was thinking smallest physical size V8 to use in a small lightweight car. If you use a standard sized block like a sbc or sbf, you might as well go as big on the cubes as they made. Not what I was looking for, I was thinking out of the box....
    I was also referring to actual production and use in a vehicle, one off's and design mules don't count.
    I changed the title so maybe it's clearer now...
    VANDENPLAS and fiftyv8 like this.
  27. lake_harley
    lake_harley
    I've come up with so many ideas that my wife doesn't even question them any more. She just listens and (likely) thinks to herself, "This too shall pass". It generally does, but I've heard that dreaming and thinking keeps the old gray matter functioning. :D
    Lynn
    pitman and VANDENPLAS like this.
  28. BamaMav
    BamaMav
    from Berry, AL
    I like to think that, too. If you keep dreaming, thinking, and planning, you keep your mind sharp. I know when I'm faced with fabbing something up, I'll think on it a while, sometimes days, then it will usually come to me what I need to do. Now if I could just build with my hands what my mind dreams up, that would be amazing in itself!
    Deuces likes this.
  29. 65pacecar
    65pacecar
    from KY, AZ
    Friend of.mine put the 215 Buick in a 58 MGA, nice little engine and a great combo for his car. Backed it up with a 5 Speed from a late 80s GM F-Body
    Sent from my SAMSUNG-SM-G920A using The H.A.M.B. mobile app
    alanp561 and TrailerTrashToo like this.
  30. badshifter
    badshifter
    At 122 CI the Ferrari 208 GT4 V8 may be one of the smallest production V8 engines. But the chances of stumbling across one in a junkyard are pretty slim. Unless you are on a reality TV show. Then odds are you find one. For almost nothing.
    winduptoy, alanp561, Jet96 and 3 others like this.
