  1. Squablow
    Squablow
    Perfect car for a custom. I like your color combination too. Here's a before pic of my girlfriend's 51, along with some photoshops that OahuEli did and finally the actual finished product. Nearly the exact same colors you have picked out. Also, I'm on board for the Cadillac caps, whitewalls, spotlights, and lake pipes you have picked out (although I'd not use the 3 tip ones, they're kinda 80's style) but I'd leave the visor.
    This is the before pic
    This is the color scheme she originally wanted, in photoshop rendering
    This was a second option
    And the third option, which really struck us both as the right choice once we saw it.
    Then here's the actual car, in the same spot, after painting it to match the photoshop.
    And a finished/assembled pic, later at a car show
    She has spotlights to go on the car as well, just haven't gotten around to installing them yet.
    OahuEli, Copper Top, Ned Ludd and 3 others like this.
  2. madfish
    madfish
  3. Rot 'n Kustom
    Rot 'n Kustom
    Saw your car and had to do this.
    swade41 likes this.
  4. madfish
    madfish
    swade41, D-Russ and Rot 'n Kustom like this.
  5. madfish
    madfish
    @RMONTY
    Look, Ma, here's one we didn't have to photoshop. The real deal.
    Peanut 1959 and RMONTY like this.
    Peanut 1959 and madfish like this.
  7. RMONTY
    RMONTY
    themoose likes this.
  8. There was a guy in Apache Flats who used to cut through the middle and put his TIG on really low... :p:Do_O
    D-Russ likes this.
  9. StefanS
    StefanS
    from Maryland
    Any way I can get one of you fine folks to change my car from this yellow to this green with a black top and wheels? 20190706_145039.jpg 20200901_104409.jpg 20130905_185637.jpg
  10. Stan Back
    Stan Back
    Nothing says "race" like snap-on Moon discs.
    D-Russ likes this.
  11. madfish
    madfish
    @Stan Back
    Nothing says "race" like snap-on Moon discs.[/QUOTE]
    slv63, themoose and D-Russ like this.
  12. verde742
    verde742
    showed you , didn't HE !!!!!
  13. Stan Back
    Stan Back
    Me bad.
    I guess I'm just used to Dzus buttons. Tried the self-tapping screws once, lost a couple of discs as the GM wheels liked to flex. Never bothered to check the air pressure frequently as I was too lazy to unscrew them and screw them back on – plus that makes the screws even looser. The solution to that is to move the valve stems inside, but that's a pain in the ass to get under and read them.
    slv63 and verde742 like this.
  14. verde742
    verde742
    YER Correct on every issue,
    I have tried also, cause I love the look. Even put them on my car trailer, lost three out of four on a hundred mile trip...:(:(:mad:
    Squablow, slv63 and madfish like this.
  16. Peanut 1959
    Peanut 1959
    That's crazy, there's an Apache Flats just outside town, here!
  17. Hey, at least I didn't say St. Martins, or Etterville. I was going to say "Tempe" but I KNEW he wouldn't believe that one!
    (And actually, I messed up...I was thinking Tortilla Flat and mixed my metaphors...)
    Peanut 1959 likes this.
  18. silent rick
    silent rick
    er, a friend of a friend wanted to know what the bad news T would look like without the whitewalls, just blackwall cheater slicks on the back and blackwall tires mounted to hallcraft laced spindle mounts up front.
  19. silent rick
    silent rick
  20. I've done this a couple times now with great results, I loctite a button head stainless machine screw in from the backside, then run a standard lock washer and nut onto the "stud", add Moon disc then little washer and nylock nut.
    They've never came loose in the many years of doing it, now of course they would look racier with dzus but that would require someone to tig the bracket on the aluminum rim.
    drdave and verde742 like this.
  21. WordSmith
    WordSmith
    The photo I wanted photoshopped was removed because the donor car for the grill had billet wheels? You guys are worse than Southern Baptists.
    Let's see if we can get this again. I've always wanted to see the Edsel grill replaced with that of a '32 Ford. I'm posting 2 different angles of the Edsel, but I'll leave it to you to find a suitable '32 Ford grill.
  22. There's NO and then there's HELL NO!!:eek:
    Bdamfino, swade41, madfish and 3 others like this.
  23. Peanut 1959
    Peanut 1959
  24. WordSmith
    WordSmith
    Hmmm... can you widen the grill to the same width as a normal '32 Ford grill and narrow the bumpers?
  25. That's just wrong on so many levels.
    Mick
    swade41 and themoose like this.
    Groucho and 51504bat like this.
  27. WordSmith
    WordSmith
    Thanks!
    I have to say, that's not all that bad. Not all that good, either, I suppose, but not all that bad.
  28. Rot 'n Kustom
    Rot 'n Kustom
    Facel Vega integrated a vertical grille in a horizontal face by balancing with stacked quad lights. Facel Vega.jpg
    Nads and WordSmith like this.
  29. Stan Back
    Stan Back
    Had one of those, sold it for $8500.
    A couple years ago I saw it was a "barn find". Certainly looked like it. Nothing changed, just deteriorated. Sold for $171,000 (supposedly).
