  1. Ned Ludd
    Ned Ludd
    DKW F7s could be had with wires in some versions:
    They were front-drive, with transverse 2-stroke twins, a sort of back-to-front motorbike layout. I think the layout is quite central to the concept and character of the car. It's always a pity when someone hot-rods an unusual car and first of all removes all the unusualness.
    I wouldn't pick a front-drive car to start with, generally, but if someone gave me a DKW F2/4/5/7/8 I'd approach it from a front-drive angle. It's a light car at about 1500lbs; I'd be thinking pre-war hot hatch - which ties in nicely with the streamline/fastback idea. How about a large motorbike engine/gearbox, some liquid-cooled 1100 or so, say, installed back to front? We'd have to reverse the direction of rotation, so add the ring and pinion out of a fwd transaxle driven off the drive sprocket? Reverse becomes a problem, so perhaps rather a transaxle turned upside-down, with the final drive at the front, chain-driven by a transverse engine behind it?
    I'd keep the structural plywood body construction, too.
  2. manjusri
    manjusri
    from US
    here's a couple, with and without whitewalls
  3. oldrelics
    oldrelics
    from Calgary
    Hey guys, I need to weld up the hole in my hood that someone cut for an aircleaner, plus I have to fix some rust in the front center of the hood. I can't match up the salmon paint right now but I do have the white. Can someone photoshop the center '3rd' of the hood white leaving the the outer '3rds' salmon? Kinda like the old flat black muscle car hoods but in white.
    Thanks
  4. A quick one
      174.9 KB
  5. oldrelics
    oldrelics
    from Calgary
    Awesome, thanks!
  6. Tim_with_a_T
    Tim_with_a_T
    Could someone help with this? It would be greatly appreciated!
  7. MoparJoel
    MoparJoel
    Took a couple hours but got your interior and somewhat of a similar color, though I'm not good with glossing up flat paint, maybe someone else could go off of this and make it better, but this was definelty one of the more difficult ones I've done. hope you like it.
  8. Originally Posted by Tim_with_a_T [​IMG]
    Would someone please give this a touch of Washington Blue? (Frame, body, and grill shell). I'd like a black interior and black suspension, too. Thank you very much in advance. I'm on the fence between Washington Blue, Kewanee Green, and Windsor Maroon...
    Here's another version to take a look at....
  9. TxRat
    TxRat
    ImageUploadedByH.A.M.B.1394810108.103169.jpg can someone crop in chrome steel wheels and a dropped stance.
    Thanks!!
  10. [​IMG]
  11. TxRat
    TxRat
    Rad!!! Thanks!!
  12. Lee_Ford
    Lee_Ford
    A little different stripe...
  13. TxRat
    TxRat
    This is my buddy's shoebox. Can you put a 2" front 3" rear chop on it and maybe a bit of a section job on it. Thanks. ImageUploadedByH.A.M.B.1394924338.895789.jpg
  14. OahuEli
    OahuEli
    from Hawaii
    Here's a bit of roof streamlining and a bit lower. I'll try to come up with some whitewalls and possibly a Gasser style version.
    [​IMG][/URL][/IMG][​IMG]
  15. This is my buddy's shoebox. Can you put a 2" front 3" rear chop on it and maybe a bit of a section job on it. Thanks. [​IMG]
  16. TxRat
    TxRat
    Thanks!!!!!
  17. Ned Ludd
    Ned Ludd
    I'm not so good with radical colour changes myself, but I had a go:
    Sorry about the '80s Audi wheels: it just seemed to want them.
  18. whtbaron
    whtbaron
    from manitoba
    Ned's work points out 2 issues with the car in it's stock form. One, the rearend needs to move back about 3 inches to center the back wheels, and two, the back of the roof needs to come down to avoid that awkward rake to the windshield. I'm not sure eliminating the trunk bump is really worth the work though, it would look good with the roof and wheelwell issues fixed ( the bent wheel opening isn't helping either). For some reason I see this car in a deep dark blue/green teal or a burgundy. Just my 2 cents...
  19. Jibs
    Jibs
    OK, I've got one for you guys. My coupe needs chopped 2" side windows are 15" high now. Coupe also needs pie crust cheater slicks on Halibrand 5 slot as cast wheels with as cast torque thrust on the front. Or leave the wheels white and paint the car gloss black or gloss maroon. Thanks Jibs
      178.7 KB
  20. OK, I've got one for you guys. My coupe needs chopped 2" side windows are 15" high now. Coupe also needs pie crust cheater slicks on Halibrand 5 slot as cast wheels with as cast torque thrust on the front. Or leave the wheels white and paint the car gloss black or gloss maroon. Thanks Jibs
    <fieldset class="fieldset"> <legend>Attached Thumbnails</legend> [​IMG]
    </fieldset>
  21. Tim_with_a_T
    Tim_with_a_T
    themoose:
    Thank you so much! It looks great! I'm very impressed with the upholstery! Hats off to you- you just made my day.
  22. Tim_with_a_T
    Tim_with_a_T
    MoparJoel,
    I don't see an image? Could you repost please?
  23. Tim_with_a_T
    Tim_with_a_T
    MoparJoel,
    Nevermind. I'm sorry - my work browser filtered out the photo. That looks awesome too! Thank you very much for taking the time to do that. I seriously appreciate it.
  24. Jibs
    Jibs
    Wow, that's exactly what I am working toward fantastic!!! Thanks Jibs
  25. verde742
    verde742
    Now please lower it, not to the ground, reasonably please
  26. Could someone please paint this car white, put smaller wheels and black walls with caps of your choice, and give the bumpers a brushed look? Maybe a little lower if you wish. I just want to visualize my idea for my 62. Thanks!
  27. Could someone please paint this car white, put smaller wheels and black walls with caps of your choice, and give the bumpers a brushed look? Maybe a little lower if you wish. I just want to visualize my idea for my 62. Thanks!
    I couldn't help myself with the tires and wheels:rolleyes:
  28. [​IMG]
  29. Not too bad at all. Could you try the hubcaps? Thanks
  30. LN7 NUT
    LN7 NUT
    How about some radiused wheel wells using front fender openings?
    And here is a shaved vent windowless version with a tucked front bumper.
    Sectioned
    Chopped
    And then turned into a skateboard...
