Hot Rods The Model A Dash Picture Thread
Discussion in 'The Hokey Ass Message Board' started by panhead_pete, Sep 5, 2020.
  1. panhead_pete
    panhead_pete
    Been looking for ideas for a Model A dash and thought it might be worthwhile starting a pic thread so its all in one place. Go! :)
    dana barlow likes this.
  2. Dave Mc
    Dave Mc
    I am using the original tank. To accommodate the modern gauges I cut the dash out of an extra tank and hung it from the valance. The gas sight has a jewelers lupe glued to the back to magnify the original gas sight behind it. Also put a tiny 12 volt light back there to make it easier to see when lights are turned on.
    The other gauges are Model A speedo, SW mechanical oil pressure and water temp. Bottom row are SW ammeter and a clock.
    I fabbed a lower dash rail. It has switches to the left of column and radio on the far right, below the tank. I was able to tie the sides of lower dash into inside of cowl. I hope this helps.
  4. [​IMG]
    I don't like to get them too far from stock.
  5. Chicster
    Chicster
    1. Missouri H.A.M.B.ers
  6. lake_harley
    lake_harley
    I hope I'm not messing up the intent of this thread, but if anyone has photos of 30/31 dashes that are still running the stock, functioning gas tank, I'd love to see them. Maybe just make note that the tank is still functioning as the gas tank.
    If this request is contrary to the intent or interest of the thread, just let me know and I'll delete.
    Thanks.
    Lynn
    panhead_pete likes this.
  7. Dave Mc
    Dave Mc
    This is my Dads' 31 , has V6 Chevy power with 39 Ford Tranny , still using the Stock Tank
    kadillackid, Stogy, GordonC and 2 others like this.
  8. buford36
    buford36
    from Maine
    clem, kadillackid, Stogy and 10 others like this.
  9. scrap metal 48
    scrap metal 48
    sedan motor & interior 006_LI.jpg 100_0244.JPG MR 800 for sale 008.JPG MR 800 for sale 008.JPG **clic pic** 100_0244.JPG
  10. dana barlow
    dana barlow
    from Miami Fla.
    1. Y-blocks
    I like simple an clean. Other then oil,temp,speed,also a tach. My old dash header was pretty rusted n had a horn hole drilled in left side,so I carved a new one out of some clear grain an matched it to rest of wood,steering wheel an rear cockpit lip.
    kadillackid, Stogy, GordonC and 3 others like this.
  11. Hotrodmyk
    Hotrodmyk
    1. Northwest HAMBers
    Not mine but I found this one to be simple and clean.
  12. Hotrodderman
    Hotrodderman
    40 dash 2.JPG I installed an original 40 Ford dash in mine.
  13. GordonC
    GordonC
    Have a Brookville 32 dash for a model A in mine. Had to modify the lower part to follow the contour of the aluminum gauge panel I used.
    kadillackid, hfh, Stogy and 4 others like this.
  14. jaracer
    jaracer
  15. jaracer
    jaracer
  16. scrap metal 48
    scrap metal 48
    "jaracer, A little more finished. Is that a 1949 Ford speedo?? It looks great in your dash....
    Stogy likes this.
  17. Dirty Dug
    Dirty Dug
  18. Joe Blow
    Joe Blow
    Doing some interior work, wiring etc.
  19. lake_harley
    lake_harley
    hotrodmyk....The yellow car/dash you posted, do you know much about the car other than having the photo? I wondered if the gauges are thin enough to fit in the area behind the small panel. There's just not a lot of room between the tank and the panel on a stock A.
    Lynn
    Dave Mc likes this.
  20. Working on my dash will be using stock gas tank with fuel gauge, machined bronze bushing to space out instruments and starter button in center[​IMG][​IMG][​IMG]
  22. wackdaddy
    wackdaddy
  23. Blake 27
    Blake 27
    Dave Mc likes this.
  24. hotrodjack33
    hotrodjack33
    "32 Pickup dash narrowed, in a '31 Slantwindow.
  25. C0ra1l1
    C0ra1l1
  26. continentaljohn
    continentaljohn
    A 1929 roadster with a 1936 ford dash with originals gas tank in place uncut. It also has 1936 steering column drop and tube .. image.jpg
  27. Justin in PA
    Justin in PA
  28. Dave Mc
    Dave Mc
    The Guages in my 29 are from SPEEDHUT and are short enough to fit in the stock tank with no cutting
    kadillackid and lake_harley like this.
  29. Kiwi 4d
    Kiwi 4d
    Some very nice dash panels right here. There are also a couple of glaring tacky what not to do your dash also.
