Projects The "Minges" 31 coupe
Discussion in 'The Hokey Ass Message Board' started by cornfieldcustoms, Oct 2, 2013.
  1. cornfieldcustoms
    cornfieldcustoms
    new and old
    new one in
    both new ( front ) braces installed
    making the sheet metal panels that will separate the passenger compartment from the trunk area
    made the final body mounts and welded them to frame, drilled to be bolt able
    lots of grinding on the welds to get the sheet metal to lay flat
    floors getting welded in
    started working on the steering box a little today. it is a reversed corvair box, i am going to run it as cowl steering. so i have to make an extension to get the pitman arm to the out side of the body,and make the pitman arm.
    here is the draft of the plan
    all the pieces machined, after a few hours turning handles lol
    close up of the pitman arm i made
    the mess i made
    everything bolted up on the work table, there will be carrier bearing installed when the assembly is installed in the car
  2. cornfieldcustoms
    cornfieldcustoms
    made these little brackets that bolt to the fire wall that the hood latched hook to
    made a support plate that will help spread out the weight of the oil filter can on the fire wall, and it helps dress it up a little
    with the filter can on
    then moved on to more work on the pedals/ steering. it is all going to be one unit under the dash. here is the pedal assembly with the steering box mocked up to it, you cant see the pedals in the first pic, i took them off to make it easier to get in and out of the car
    pitman arm on the car for the first time
    bent up a tube that welds to the cowl/ door post, i will be attaching brackets to help support the steering/ pedal assembly
    more of the supports coming together. the collar to the right with the upright will be split in half horizontally with tabs welded to it so it can be bolted together. this way the steering box bracket can be removed if need be. the collar to the left of the clamp collar is a pivot that will be part of the gas pedal (cardboard template of the pedal can be seen)
    here is a close up shot of how the bracket attaches to the box, using the 3 bolt locations that hold the side cap/ adjuster on. using spacers and plate to attach the tube to. you can also see part of the pedals in this pic, still need to attach the brake pedal arm to the pivot
    working on the steering a lot more, trying to get it all fabricated and working. so here it is after a ton of hours
    had to make a custom brass bushing to support the steering shaft, a huge thanks to Josh Shaw for his help on a saturday afternoon machining job
    the clamp to attach the bushing to the tube work
    starting to look like something
    made some brackets to support the steering shaft from the wheel
    then had to make a steering column clamp to support the column and steering wheel
    and the finished product, just need to finish up the pedals
  3. cornfieldcustoms
    cornfieldcustoms
    worked on the pedal assembly for a while these week end, got them all built and working
    got the pedal/ steering assembly fully welded, sand blasted, primed and re installed
    then i thought it would be a good time take the old wood out of the roof and get the new wood kit in. started pulling the wood on the passenger side and noticed some cracking in the sheet metal. dug a little deeper and found a ton of led, and a lot of bad sheet metal work when it was chopped
  4. cornfieldcustoms
    cornfieldcustoms
    so i figured i would start on the roof side panels and work my way back, and down. spent a few hours with the hammer and dollie and got the roof pretty straight. then, cleaned the inside the roof, and put some black paint in, and started installing the passenger side roof wood.
    metal working my way around the roof
    now we are all up to date, again i am sorry for all the posts but now i will be updating as i progress further on this car, so stay tuned!!!!!!
  5. SherrillHotrods
    SherrillHotrods
    Man I wish had a garage so I could get started on my 30. This work is amazing!
  6. louisb
    louisb
    Great work so far.
    Thanks,
    --louis
  7. BAILEIGH INC
    BAILEIGH INC
    Alliance Vendor
    :cool: Lookin good man
  8. alfin32
    alfin32
    from Essex, Ma.
    Fantastic work, congrats!
  9. Barrelnose pickup
    Barrelnose pickup
    Great work,love the fact you have kept the 31 grill shell!
  10. Beautiful work. What decklid hinges did you use?
  11. cornfieldcustoms
    cornfieldcustoms
    thanks guys
    not sure on the hinges, they were a swap meet find that a buddy had
  12. hotrodderhaag
    hotrodderhaag
    I noticed your picture, why the F%#£ does everyone have a belly tank hanging in there garage accept me!?! Nice car BTW love the flathead
  13. gnichols
    gnichols
    from Tampa, FL
    Very nice work, thanx for posting all those build pix! Gary
  14. Garry Carter
    Garry Carter
    Absolutely awesome metal shaping. And the quality of your thoughts (not to mention the execution of them) ain't bad either. Congratulations on a superb piece of work!
  15. Mart
    Mart
    Great thread, lots of excellent work going on here, thanks for the step by step pictures.
    Mart.
  16. drmrman
    drmrman
    from new Jersey
    Unreal. So bitchen
  17. Daddy_O
    Daddy_O
    thanks guys
    Quote:
    <TABLE border=0 cellSpacing=0 cellPadding=6 width="100%"><TBODY><TR><TD style="BORDER-BOTTOM: 1px inset; BORDER-LEFT: 1px inset; BORDER-TOP: 1px inset; BORDER-RIGHT: 1px inset" class=alt2>Originally Posted by High Class Rat [​IMG]
    </TD></TR></TBODY></TABLE>
    Without a closer look, decklid hinges appear like they might be 1940 Chevy sedan.
    Definitely look GM.
    <!-- / message -->
  18. boutlaw
    boutlaw
    Wow, just wow. Definitely subscribed, makes me want to build another one. You Sir are a master metalsmith. Thanks for posting the details.
  19. inkstain27
    inkstain27
    Nice!
    Subscribed
  20. bobo1
    bobo1
    from France
    Work extraordinary on your coupe ;)
  21. Sparkswillfly
    Sparkswillfly
    from Colorado
    Really like it. Keep up the great work.
  22. draggler
    draggler
    Damn fine work there!
  23. LKR
    LKR
    from Australia
    you do some nice work!
  24. putz
    putz
    from wisc.
    Wow!!! Great work ,thank you for the post ............
  25. AHotRod
    AHotRod
    Great job once again!!!
  26. hammered30
    hammered30
    from west aus
    That sure is some fine work
  27. Super Streak
    Super Streak
    from Florida
    Awesome job, great metal work. That is going to be one kick-ass model A, especially with a flathead.
  28. Fantastic build!
  29. cornfieldcustoms
    cornfieldcustoms
    finally able to get back to this one.
    started to put the visor on and the fitment was not up to par, so i had to trim the ends off and make them fit right. had to make a couple pieces for it to make it work
    one side fitting better
    and now for the fun part. the owner wanted to louver the hood, and the visor and wanted them to line up with the louvers on the decklid. easy enough. so then i remembered i had started shaping an aluminum insert for a buddys coupe that we never finished. so why not finish it and put it on this coupe and louver it to death and make them all match. so here is where i was after 2 days worth of shaping, and louvering. still needs a little fine tuning but looking good
    chop job and kiwijeff like this.
  30. englands54
    englands54
