Projects The Kustom Falcon
Discussion in 'The Hokey Ass Message Board' started by Kustom.Falcon, Sep 13, 2012.
  1. 65CometRagTop
    65CometRagTop
    No worries on the pedal box. I combined a Mountaineer pedal box and a Comet manual pedal box to come up with what I needed for my 4R70W trans. As Roy says the transmission tunnel will have to be altered. That transmission is a big sucker so I altered a lot of the tunnel to get mine to fit right.
  2. Kustom.Falcon
    Kustom.Falcon
    Are you running an aftermarket front end, or the shock towers? As far as my Falcon friends are concerned - and their AOD Falcons - there isn't much modification outside of the x-member and firewall massaging.
    Kustom Falcon Build Thread:
    http://www.jalopyjournal.com/forum/showthread.php?t=734282
  3. 65CometRagTop
    65CometRagTop
    I have the stock front suspension with the shock towers (cut down). When I got the car most of the transmission tunnel was gone along with the cross member and half the trans support that goes over the transmission was gone too. The transmission I am using is the computer controlled trans from a 1998 Mountaineer so it is a little different than yours. Roy has experience with the trans you are using.
  4. Kustom.Falcon
    Kustom.Falcon
  5. Veach
    Veach
  6. 65COMET
    65COMET
    Kustom Falcon;you DO NOT need to alter the firewall as the area where the bellhousing fits is fine.The area that needs work is the floor brace that connects the rear of the subframes.That floor brace needs to either be notched or moved back in order to get the tail of your engine/trans angle up! I did an AOD swap in a Falcon and a Comet[same chassis],it is not a big deal.The reason is if you just lower the tail,with a lowered trans mount,you end up with sever drive line vibrations[been there],we tried a zillion rear pinion angles[up and down] but could NEVER get rid of the vibration[only moved the onset].The Falcon was lowered,not as much as yours,and so was the Comet.Both cars have stock type front suspensions.I really like the way your Falcon is turning out!! ROY.
  7. Kustom.Falcon
    Kustom.Falcon
  8. Kustom.Falcon
    Kustom.Falcon
    Alright! Got some POR-15 laid down in the areas I didn't want to patch, but needed some help, as well as general floor pan seams. This stuff is wild - I had read as much on it as I could before I pulled the trigger on it, and it seems as though it's as advertised. I took some advice of a good friend and threw in some fiberglass sheeting in some areas to strengthen the floor even more, and I'm really, really happy with it.
    Next I'm going to top coat this and the rearend/suspension housing cover.
  9. Kustom.Falcon
    Kustom.Falcon
  10. tobyflh
    tobyflh
    from Peru il
    just found this. and it is cool as hell
  11. Kustom.Falcon
    Kustom.Falcon
    Thanks Toby. Things are starting to move.
  12. 53chevtrev
    53chevtrev
    from Langley BC
    car is looking awesome man! love the paint
  13. Kustom.Falcon
    Kustom.Falcon
  14. Kustom.Falcon
    Kustom.Falcon
  15. ClearSpot
    ClearSpot
    from Michigan
  16. Kustom.Falcon
    Kustom.Falcon
    Summit. Edelbrock is the only manufacturer of tall, finned valve covers for a small block Ford I could find.
  17. 32coop
    32coop
    from Australia
    Love the car, dumb ass question. What year is the motor? I'm looking at putting one in my 35. Hard to get a donor car with everything cheap here in oz. cheers aaron.
  18. Kustom.Falcon
    Kustom.Falcon
  19. 32coop
    32coop
    from Australia
    Thanks mate. Looking good.
  20. Kustom.Falcon
    Kustom.Falcon
    I've got a little less than an hour left of Christmas day, and a week until I hit a milestone birthday, and a new year. I figure this would be a good time to say "thank you," to all the incredible people that have helped me along the way of getting the Falcon started. As a group of seriously talented guys you're all friends to me. Thank you!
  21. JiiTee
    JiiTee
    from Finland
    Very cool Falcon! Keep up the great work!
  22. OK, here's the rundown on the engine. '89 5.0 block out of a Lincoln Town Car, Trick Flow 117 aluminum heads with ARP studs and nuts holding them down. Flat top cast Speed Pro pistons with coated skirts, stock rods with ARP bolts, stock crank std./std., Tru Roller timing set. The cam is a mild "street" grind that will work good with his AOD but have a nice sound and rev to 6000+, Ford Motor Sports roller lifters. Trick Flow chromolly push rods (6.550") and Trick Flow roller rockers. Of course the rotating assembliy was balanced to within 1g, I balance every engine I build and I recomend it to everyone. Just makes them run that much better. ;)
  23. Kustom.Falcon
    Kustom.Falcon
    Those rockers are so nice, it's a shame they have to be covered.
  24. zomb1e
    zomb1e
    any more progress? im so in love with this car!
  25. Kustom.Falcon
    Kustom.Falcon
    Hey Zombie, yeah a little here and there, but nothing worth posting yet. I'm upgrading the the breaks right now. Just pulled the calipers and brackets off the front end (simple GM type) in trade for some Wilwood black dynalites to match the back.
    I also just had the dash pieces shot with some of that spray-on chrome. It didn't go as well as it could have if the pieces were new, but they still look good.
    In the picture, the chevron emblems are actually chromed, the dash piece is "painted."
  26. F91
    F91
    Wow! That engine is beautiful. As is the car
  27. 65CometRagTop
    65CometRagTop
    That spray on chrome looks good. I have seen several thing about it on TV. I am assuming that is mainly for plastic parts. Do you have a sense of how durable it is? I’m just trying to figure out where it would be good to use it and where it would not.
  28. 64falconsix
    64falconsix
    from Daphne Al.
    Cool custom Falcon build. I like the paint color.
  29. stationWAGONS
    stationWAGONS
    from Vegas
    Like it. Definitely not the same old s___!
  30. Kustom.Falcon
    Kustom.Falcon
    Haha! Thanks.
    As a sidenote, I get to scratch one off my "experience of a lifetime" list. I got to talk cars with Thom Taylor for 15 minutes at the GNRS! And the best part is that my Falcon used to belong to a friend of his, and he remembered everything about it.
    Last year I met Steve Stanford, this year Thom Taylor... Where are you at Norwell?!
