Event Coverage The Hudson Adventure
Discussion in 'The Hokey Ass Message Board' started by squirrel, Aug 9, 2019.
  1. I've seen some crazy stuff fixed with JB Weld. A buddy had a Mercury outboard with a damaged prop shaft, badly grooved and the wiped out bearing killed the housing. JB Weld saved the shaft and even turned it on a lathe.
  2. Seems like that car would pull 4.11's with the torque they have. What's the O/D ratio? Can you run 65 now?
  3. Bill S
    Bill S
    When I was a teenager my dad had a Hudson 8 cylinder with overdrive. Remember driving from Calif to NY and back. That thing would realy go.
    In Newport Ca. a few years back there was a Hudson hard top. Man was that a nice car. Stock all the way.
  4. squirrel
    It runs about 2500 at 60 in overdrive.
    The engine is making a bit more noise than it used to. I changed the oil again, went a little heavier viscosity. I guess I'll see what happens.
    I'm in Monterey.
    Sent from my Trimline
  5. dana barlow
    dana barlow
    from Miami Fla.
    I ran more RPM,back in the early 60s,but my buddy Rob n I were only going around a oval. Have fun !!! Hudson RobBean n DanaBarlow built an raced.jpg
    Woogeroo, dwollam, wicarnut and 15 others like this.
  6. squirrel
    A guy near San Jose was selling some Hudson parts. I got a 4.11 pumpkin and a couple cam cores.
    edit: got the picture to load finally
    mgtstumpy, dwollam, wicarnut and 17 others like this.
  7. Parking lot swap from the 4:56's?
    kidcampbell71 likes this.
  8. squirrel
    I don't have pullers, etc. So I'll do that swap at home. If I make it.
  9. flatford39
    flatford39
    Got one of my old "Motors" books out and it looks like you can do it without pulling the rear entirely out. There is an inspection cover on the ass end that probably gives you access to the internals but you do need to pull the axles. Just don't lose the shims.
    It appears that sucker might have been open drive as well.
    Not used to these "modern cars" that's for sure.
    It's a good thing you left your pullers at home as I suspect you would try to do it.
  10. Find a swanky hotel, pull up into the valet parking drive, identify your self as "Dr. Hudson" and see if the attendant will park the car for you. When he can't, or won't, tell him your not leaving until you can take a couple pictures of him standing next to the car. Email a copy to the hotel management. :D
  11. the oil soup
    the oil soup
    from Tucson,AZ
    . JB-Weld won't stand up to the heat, I used it to patch a muffler leak and once it gets hot it melts and stinks like hell!
  12. Cosmo49
    Cosmo49
    .70 overdrive X 4.56 = 3.192 Taller tires are of course the 'poor man's overdrive', that would help.
  13. squirrel
    taller tires are kind of expensive, not for the poor man!
    dwollam, Boryca, kiwijeff and 5 others like this.
  14. manyolcars
    manyolcars
    It will hold up very well for a groove worn into a shaft caused by the seal. It works well for gluing in a chunk of the block knocked out by a broken rod
    alanp561 likes this.
  15. squirrel
    I'm not worried about the oil consumption, I can live with that. but if it loses a bearing, I'm in deep doo-doo.
  16. Lets hope Tigger doesn't find...
  17. Ick, that might be the new noise you are talking about. Hopefully it's a tick and not a knock.
  18. That is pretty high considering you have got OD. Mine with the 3.89 rear and no OD runs around 2800 at 60.
  19. I had an Uncle that drive Hudson’s until he couldn’t get a newer one, then he switched to a used ‘57 Ford. He never was happy with the Fords after that. Being a kid, I didn’t get it. My Dad drove Chevies.
  20. What weight oil are you running? Maybe you can go to 15W-50 or 20W-50 to get through this. I had an OT V-6 Capri that was showing the oil pressure light at idle, would shut right off/engine would INSTANTLY stop rotating when the key was turned off. Eventually I did a bearing swap in the driveway with the engine still in the car, but 20W-50 allowed the car to live until I got to do it.
    there's big debate regarding oils in OT Ford CV's....OEM recommendation is 5W-20, lots of guys insist 5W-30 is better for quiet long life, 5W-20 was only to get better EPA numbers, and then one guy told of a taxi fleet in NYC, used 15W-40 Rotella on all CV's and at 500,000 the engine bores were still showing cross hatch marks. FWIW.
    Truck64 likes this.
  21. Atwater Mike
    Atwater Mike
    Wow, Jim! A Dempsey Wilson cam! Some 'history' there.
    I see the recipient was an 'Elmer' something...I'm from Santa Clara, have known some 'Elmers'...:rolleyes: but not this one. :D
    squirrel likes this.
  22. DDDenny
    Yeh, can you imagine the look on the guys face down at Pep Boys when you ask for bearings for a Hudson.
    hotrodharry2 likes this.
  23. dirty old man
    dirty old man
    Jim, I just found this thread this morning and just read it all, great stuff as I've always enjoyed your posts, more so since last year when I got to meet you @ Atlanta Dragway for Drag Week.
    Now you add to it with an adventure in a Hudson:cool: I once owned a '53 Super Wasp, which was 2 carbs on a 262cid engine, and a dual range 4 speed
    Hydramatic trans.
    Used it as my DD for quite awhile way back when. Also had some friends who operated a ,shop here in town, 4 brothers all also involved with making, and hauling, shine liquor in a big way. They used quite a few Hornets in this part of their work. Those coupes had a damn big trunk:)
    Later on, in the late 50s, one of the brothers took a '53 coupe equipped with the hydramatic and installed a Cadillac OHV V8:cool: T hat was one fast road car:)
    Now if one of you young whippersnappers will explain what Instagram is and how to negotiate around on it, I'll follow Jim there also!!!!!!!!!!
    HEY I'M SERIOUS, I'M ALMOST 82 AND HAVE NO CLUE ABOUT INSTAGRAM!!!!!!!!!!!
  24. Gotgas
    Gotgas
    from DFW USA
  25. Cosmo49
    Cosmo49
    #fabuloushudsonhornet
    Is already taken, have you decided on another Instagram account?
  26. squirrel
    That is the hash tag I'm using for my car. My user name is jforb427
    kiwijeff and hans mercman like this.
  27. squirrel
    Woogeroo, mgtstumpy, dwollam and 6 others like this.
  28. flatford39
    flatford39
    Interesting...the rings must be holding as they don't look full of oil. You do like to run on a budget don't you. I would have at least put a set of plugs and points in that thing before I left...but what do I know. You've been thru three of these things now.
  29. /\ /\ Hahaha. :) That's why I love these threads. Go Squirrel, go.
    hotrodharry2 and Nostrebor like this.
  30. BJR
    BJR
    So those plugs must have come with the car! :D
