Projects *DONE!!* The Flamedabone '40 Ford Coupe build thread.
Discussion in 'The Hokey Ass Message Board' started by flamedabone, Feb 26, 2017.
  1. Thor1
    Thor1
    Abone,
    That is a good compromise. The car still looks awesome and the stance is still killer.
    Thor
    brEad likes this.
  2. BITCHIN'!!
    Xman likes this.
  3. neilswheels
    neilswheels
    from England
    I, I say 'I', Marco installed a T5 in my 40, there's some info on my build thread, if the pisc are still there, or I can email you some if you want. Basically a split kit and modified the stock bottom x member. Its behind a 348, so a pretty big motor physically, seems to just about fit tho.
  4. neilswheels
    neilswheels
    from England
    So, how did you get the back end and those wheels that low? I'm looking at 8 inch small window Halibrands a little further down the line, so would be very interested on axle width info. I'm running an A rear spring and will be dropping in a QC center on 40 bells, that will need a 'light tickling' to get it all in there. Car looks the 'nuts', love the front crossmember mod, is that a dropped spring and axle, or stock spring and dropped axle?
  5. Man, so cool. I want those wheels, tires and stance for my 38 Chevy re-do that needs to happen.
  6. flamedabone
    flamedabone
    Neil, the rear end is a 9 inch ford that measures 52.5" wheel surface to wheel surface. If you use a 1-800 leaf spring kit, you will have to move the leafs inboard to keep the backing plates from smashing into your u-bolt perches. With an A spring, you should be good. Also, I used an 8 inch wheel that has the front space of a 10 inch wheel, so your measurements might also be different. The best way to do it is get the wheels and tires you want, put them exactly where they go, then measure wheel mounting surface to wheel mounting surface. That will be the total width of your rear end including brake drums.
    Here is a quickie Saturday update:
    This car has leaf springs, lowering blocks, a big motor and a 5 speed. All that is a recipe for wheel hopping disaster. To keep that from happening, I made a ghetto torque arm. The leaf springs still hold the car up and locate the rear end, al this arm does is keep the leaf spring from wrapping or oscillating on a hard launch.
    Just square thickwall tube and a 3/4 rod end.
    Here it is installed.
    This is why it works without binding the whole rear suspension. The arm is mounted to a shackle that allows the arm to effectively lengthen and shorten during the range of motion of the leaf springs. Kind of like the slip yoke on a driveshaft. Ghetto, but it works.
    See ya, -Abone.
    barrnone50, treb11, Malcolm and 11 others like this.
  7. That torque arm looks very functional. Thanks for sharing that.
  8. Roadsir
    Roadsir
    Smart set-up. I'm building my A roadster on 32 rails with 1/4 elliptics and plan on making a single torque arm using all or part of some 46-48 front bones.
    Tman likes this.
  9. C Crews
    C Crews
    great work jeff.
  10. flamedabone
    flamedabone
    Bell housing is indicated, block and crank are off to the machine shop.
    Finished the firewall. Here is a rewind.
    Tacked.
    Finished the color '40 Fords are supposed to be.
    Not sure what is next...maybe a little bodywork? It ain't getting much.
    See ya, -Abone.
  11. Nicely done on the firewall.
    RODIST likes this.
  12. I like that stance, sits good
    CapeCodBob likes this.
  13. neilswheels
    neilswheels
    from England
    Thanks for the info Abone. Now I need to find info on norrowing 40 bells. Your 40 is looking good, its gonna be killer.
  14. cvstl
    cvstl
    from StL MO
    1. H.A.M.B. Chapel
    That torque arm isn't ghetto, it's a slick solution...... should work great.
  15. Squablow
    Squablow
    Great build as usual, but this picture really cracks me up. RKelly couldn't have cropped this pic more perfectly. Anyone else see it?
    cvstl and tfeverfred like this.
  16. Russco
    Russco
    from Central IL
    Haha that's too funny
    Tim likes this.
  17. Russco
    Russco
    from Central IL
    The Torque arm is genius. I may have a winter project now.
    Malcolm likes this.
  18. eberhama
    eberhama
    I'm looking to build a '40 coupe along these lines. I might have missed it, but what did you do to bolt the front spring to the crossmember with it channeled down in there that far?
  19. ***Area-51***
    ***Area-51***
    from Ohio
    anything new here?....nice!
  20. flamedabone
    flamedabone
    I haven't done anything interesting at all. Lots of grunt work. I did get the last patch panel on the thing.
    Inner.
    Outer. Still have finish welding to do and don't look at the extra vertical weld seam, operator error.....
    Eberhama: The raised cross member is something I do to all my cars with transverse leaf, but on the deluxe front end, it got the car a little too low, so it was pretty much wasted effort. The spring is held into the channel by a plate and block that bolts to the bottom of the cross member using the original U bolt holes.
    See you next time, -Abone.
    PS. I never would have caught the R Kelly thing had you not mentioned it.....
    chop job, kiwijeff and kidcampbell71 like this.
  21. eberhama
    eberhama
    I see...wondering if I can get away with reverse eye spring, cross member mod, and a fairly short tire, and skip the dropped axle to get me about where your at?
  22. flamedabone
    flamedabone
    The dash was pretty decent.
    I know it is blaspheme, but I never liked stock '40 dashes. I'm a bit of a minimalist and there is just too much crap on them for my taste. So, I welded up a bunch of stuff.
    You can't see the pearl in the pic, but it looks pretty decent in person.
    All the other progress is so boring, you wouldn't be able to stand it. Hopefully, the block will be back soon and I will have some short block building pics. My favorite.
    See ya, -Abone.
  23. Love that dash!
    Hansa1100, greaser and kidcampbell71 like this.
  24. Wow, dash looks amazing!
  25. The 39 guy
    The 39 guy
  26. Roadsir
    Roadsir
    Yeah, very cool dash!
  27. 40ford
    40ford
    from Duluth, GA
    That dash is nice!
  28. flamedabone
    flamedabone
    Finally in primer.
    Next is running the brake and fuel lines and wait for the block to get back from the machine shop.
    -Abone.
    PONTNAK123, OL 55, greaser and 11 others like this.
  29. Roothawg
    Roothawg
    I am such a slacker.
    neilswheels and brEad like this.
  30. ***Area-51***
    ***Area-51***
    from Ohio
