Projects *DONE!!* The Flamedabone '40 Ford Coupe build thread.
Discussion in 'The Hokey Ass Message Board' started by flamedabone, Feb 26, 2017.
  1. How in THEE hell did I miss this one???? Not only did I not know the 34 was on the road, I didn't know you were doing a 40 coupe. But what I really didn't know was Hedman is making a Poncho block hugger header. And all the work I went through to weld Pontiac flanges on my chevy block huggers.
    Any reason you didn't offset the motor to the passenger side of the car a little? I moved mine an inch to get steering shaft/steering box/clutch pedal/starter clearance. You need to move out here so I can keep an eye on you.
    Rocky
    jnt1957 and brEad like this.
  2. MIKE STEWART
    MIKE STEWART
  3. Who manufactures those wheels? Circle City?
  4. flamedabone
    flamedabone
    Patrick and Mike, the wheels are American Rebel, 15X5 front, 15X8 rear. The rears have a big giant front space like a 10 so they look cool and a small back space so you don't have to tub the inner fenders. I am VERY happy with them, and they are made in the United States, unlike Halibrands and you can actually make a phone call and get them unlike the Real Wheels guys.
    Finally got the pedals and the exhaust to cohabitate. Had to divorce the clutch pedal and hang is off the frame rail to get the pipe to not crash into the whole deal.
    Butchered firewall.
    Cut out the yuck.
    New stuff tacked.
    Just a quick primer coat, still needs metal work, finish work and a nice coat of Wimbledon White.
    I picked up the Y in the X member to anchor the roll bar.
    Here is the finished 4 point welded to the frame. Still need to finish the floor boards around it, but that is next time.
    See ya, -Abone.
  5. Awesome as usual Jeff!
  6. Roothawg
    Roothawg
    So, we can assume the body isn't coming back off Jeff? Thanks for the shot of the X member. That helps.
    RODIST likes this.
  7. flamedabone
    flamedabone
    Finally got the floorboards done. Holy shit, that was a lot of welding.
    Made a little reverse bump to give me a touch more throttle pedal room.
    Yes, Root. The body is on forever. Usually, the body would come off one more time for detail and paint, but not this time.
    See ya, -Abone.
  8. flamedabone
    flamedabone
    This is the 1/4 that was a little crinkled.
    Nothing good underneath.
    Made a new panel.
    Needs a tiny bit more welding, but it is damn near done. Fixed the door gap a bit and relief cut the injured 1/4. The EMS panels are VERY nice. Yes, they are always going to have to be trimmed to fit a 77 year old car, but they are pretty damn nice. (Made in the USA too.)
    Gotta go do the other side.
    See ya, -Abone.
  9. That looks great. HRP
  10. flamedabone
    flamedabone
    The most unimaginative seat brackets you will ever see.
    I took 8 inches out of the frame and foam from this mini truck seat.
    Easy side of the 1/4.
    This is where Fireball Roberts was bump drafting my car in the Southern 500 back in the day..... At least I'm pretty sure that is what happened....
    All better.
    See ya, -Abone.
  11. I am late but I am here watching.
  12. Good progress!
  13. Ha ha, exactly what I'm using!
  14. ems customer service
    thanks for buying from us,
    the ems guy
  15. Russco
    Russco
    from Central IL
    Those seat riser/ brackets are nearly identical to mine for my 64 falcon buckets
  16. motoandy
    motoandy
    from MB, SC
    Great thread . Good luck on the rest.
  17. flamedabone
    flamedabone
    All the heavy fab is done, its time to mock up the fenders.
    Finally off the jack stands for a while.
    Wheels and tires are in the right spot.
    I don't think I have ever said this before, but I think it might be....a little to low...
    Here is the original tallness.
    Way better.
    See ya, -Abone.
  18. Yum.
    Get some spare chins.;)
    lothiandon1940 likes this.
  19. godlemmy
    godlemmy
    You are the 40 ford man!!! I can only hope and steal from your thread to make my 39 sit as bitchin as your 40's.
    Sent from my SCH-I435 using H.A.M.B. mobile app
  20. godlemmy
    godlemmy
  21. Kan Kustom
    Kan Kustom
  22. Yeah, that's a tad low!! :rolleyes::)
  23. saltflats
    saltflats
    from Missouri
    Settin that low you better keep drinking lite beer.
  24. Knghtcadi
    Knghtcadi
    I don't think I've ever said I think it's too low. Bad ass
  25. Tack weld a roller skate under it.
  26. Take the chin off and fab up a flat plate with a shopping car wheel to roll out the bumps! :D
    Or look around for a standard grill,they are not as low. HRP
  27. 30TudorSedan
    30TudorSedan
    No such thing as too low! Looks perfect! I drug my chin on my '40 too much, but after a few times it was pre-flattened and gave a little extra clearance than the less than 3 inches I had!
    koolkemp and Legends47 like this.
  28. Subscribed , like this build !
  29. Brutal stance. Like @30TudorSedan said, this is a self-correcting problem. Looks great!
    30TudorSedan likes this.
  30. flamedabone
    flamedabone
    As much as I hate to ever raise anything up, I had to put 2 inches in the little car. This thing is going to be my new daily, so I have to error on the wuss side.
    I can live with it. I think. Maybe it will settle a little bit.....
    -Abone.
