History The DOHC HEMI
Discussion in 'The Hokey Ass Message Board' started by loudbang, Sep 23, 2019.
  1. loudbang
    I found one photo on the net and it led to this article from hot rod https://www.hotrod.com/articles/return-dohc-426-hemi/
    Most of the following photos from there but some from the web.
    Read the Hot Rod article it's very interesting. I had never heard of this before :)
    It was rumored about in 1964 and a couple were made for NASCAR but then disappeared. And now one has been found.
    Some of the photos get LARGE :rolleyes:
    continued below
  2. loudbang
  3. RmK57
    RmK57
    Something to counter Fords 427 SOHC, if it would have been allowed to run in the grand national series.
    lothiandon1940, Stogy and loudbang like this.
  4. Casey Riley
    Casey Riley
    from Minnesota
    Uncle Tony on youtube has a great video about the OHC V8's in the late 60's by the big 3.
    Very interesting. Especially Pontiac.
  5. loudbang
    That is exactly why they were made. It's in the article :)
  6. Casey Riley
    Casey Riley
    from Minnesota
  7. Casey Riley
    Casey Riley
    from Minnesota
  8. 73RR
    73RR
    ...some wild R&D in the 60s......
    Let us give thanks to all of the nay-sayers and bean counters for squashing them.
  9. catdad49
    catdad49
    Awesome Era! Seems like every issue of Hot Rod had factory experimental engines on the cover. Did I Buy them?! Yes, Sir.
  10. belair
    belair
    MURICA! Because we can, because too much is still not enough. Awesome engine. Thanks for posting.
  11. And if you are into models, the 1/25th scale AMT 1970 Dodge Coronet Pro Street kit has the DOHC Hemi as an optional build.......the DOHC stuff is only in the Pro Street kit, not the stock 1970 Coronet kit and is in every reissue of the Pro Street kit......andyd
    lothiandon1940, loudbang and Stogy like this.
  12. Beanscoot
    Beanscoot
    But it's not a real Hemi:
    Jalopy Joker, j hansen and loudbang like this.
  13. Deuces
    Deuces
    I also have a couple of those.... ;)
  14. Black_Sheep
    Black_Sheep
    Awesome piece of Mopar history, thanks to everyone that posted photos and links...
  15. saltflats
    saltflats
    from Missouri
    Looks like in this one they are checking cam twist.
  16. nrgwizard
    nrgwizard
    from Minn. uSA
    & then there's the Aug '57 MOTOR TREND cover pic n 1pg article(p 42) on "Chrysler 500hp 4-cam v8", w/4 carbs(97's?). Based on on a '53 hemi, '55 heads - modified for 2 cams each. 7k rpm. Gear drive to the intake cams, exh cams run w/chain from int cams. Was going to all gear drive. Builders' name was Bill(Bob) Gillelan. Was 10 month long project at article time. Looks like he worked in Moldex Tool Shop in Detroit, & balancing was done by Leo's Custom Racing Engines. No pics due to my trouble w/posting pics/scans. Sorry.
    Marcus...
    HEMI32, loudbang and Stogy like this.
  17. Hnstray
    Hnstray
    from Quincy, IL
    QUOTE="Beanscoot, post: 13256252, member: 56151"]But it's not a real Hemi:
    [​IMG][/QUOTE]
  18. Interesting that they opted for belt driven cams, as opposed to Ford's SOHC.
  19. Deuces
    Deuces
    I read in the past that this motor couldn't run under it's own power.... Not sure if it's true or not..... More info needed please...... Inquiring minds like mine would love to know!!!!... :)
    lothiandon1940 and loudbang like this.
  20. loudbang
    Did you read the article in the link it has a lot more history on it?
    lothiandon1940 likes this.
  21. Deuces
    Deuces
    No I didn't.... :(
    Maybe I should..... Duh!:confused:;)
    loudbang and lothiandon1940 like this.
  22. Jalopy Joker
    Jalopy Joker
    - I can only read pictures - Ha!
  23. Hombre
    Hombre
    View attachment 4430376 [/QUOTE]
    loudbang and Casey Riley like this.
