The Dec. 2012 Banger Meet...1243 Ho,Ho,Ho,Ho,
Discussion in 'The Hokey Ass Message Board' started by Crazydaddyo, Dec 1, 2012.
  1. Crazydaddyo
    Crazydaddyo
    Here is the banger link list .
    For the HAMB banger newbies, here are some links to a lot of banger info:
    Flat Ernie maintains the monthly link list. Every month is listed:
    http://www.jalopyjournal.com/forum/s...d.php?t=161498
    Banger basics. another info link list:
    http://www.fordgarage.com/
    http://www.billsbangers.com
    http://www.plucks329s.org/index.htm
    http://www.jalopyjournal.com/forum/s...d.php?t=251717
    http://www.jalopyjournal.com/forum/s...ad.php?t=42480
    Post #105 of link below shows flywheel lightening dimensions
    http://www.jalopyjournal.com/forum/showthread.php?t=470853&page=6
    Model B rod bearing insert numbers
    http://www.jalopyjournal.com/forum/showthread.php?p=6992484#post6992484
    Engine tuning with a Vacuum gauge
    http://www.centuryperformance.com/tuning-with-a-vacuum-gauge-spg-148.html
    Adjusting dual Strombergs:
    http://www.jalopyjournal.com/forum/showthread.php?p=6638461#post6638461
    Helpful Model A tools and tips:
    http://www.maurer-markus.ch/ford_a/tipps.index.en.html
    Elrod's stuck head tech:
    http://www.jalopyjournal.com/forum/showthread.php?t=218487
    Model A generator to alternator conversion:
    http://ejwhitneyco.com/automotive.html
    Gear ratio / speed and RPM calculator:
    http://www.accuautoparts.com/calculatorfin.jsp
    Model A master cylinder mounting bracket ideas:
    http://www.jalopyjournal.com/forum/s...73#post4953173
    Go here to read the 1931 edition of Harry Ricardo's book "The High Speed Internal Combustion Engine"
    http://www.scribd.com/full/40610101?access_key=key-w2bcjicdancrnxypd05
    Chevy Banger Stuff
    http://www.jalopyjournal.com/forum/s...d.php?t=463465
    http://www.scribd.com/doc/22469332/The-High-Speed-Internal-Combustion-Engine-Ricardo-1931
    Post 198 starts a great discussion of the shape of a flat head combustion chamber
    http://www.jalopyjournal.com/forum/showthread.php?t=470853&page=10
    Maybe these links should be posted early in each months meeting.
    If anyone knows of more, please post them.
  2. Crazydaddyo
    Crazydaddyo
    The major machine work is done on my new engine. Just have to do some port work and then it will be ready for assy.
  3. Best series of posts on the HAMB!! I ❤ my banger
  4. :D Dig it!! What color is that paint?
  5. Bluto
    Bluto
    When do you build your HAL?
  6. Crazydaddyo
    Crazydaddyo
    When I get a block. ;D
  7. Crazydaddyo
    Crazydaddyo
    It's green now, but it will be red when it's done.
  8. Is that Ford Green (stock A-early V8 color)? Who made it...looks nice!
  9. Crazydaddyo
    Crazydaddyo
    I think so. It's what ever the machine shop put on it.
  10. Bluto
    Bluto
    God! Don't wait for me........ please
  11. Lovely winter day here in Sweden today -13C (8.5F) and some fresh snow. The banger fired up nicely so I took the A for a spin :)
  12. ^ Gorgeous. As close to snow as we'll get here on the Texas Gulf Coast
  13. nickk
    nickk
    So who do I need to talk to on here to have a ford banger built with inserts and some new internals?
  14. Crazy,
    What size intakes? Are those hard seats on the intakes?
  15. I was going to drive the Model "A" today. The temperature is in the 50 range. We have a little snow on the ground in the shade. I worked on fire wood instead.Thanks for starting the thread. It is one of my favorite along with Sunday morning models.
  16. Rex_A_Lott
    Rex_A_Lott
    James Rogers over on the Fordbarn (Dreamwerks) is just outside Asheville.
    Not sure if he is over here.
  17. nickk
    nickk
    Awesome, thanks for the information!
  18. Crazydaddyo
    Crazydaddyo
    The intake valves are 1.770". No hard seats in the intake.
  19. Crazydaddyo
    Crazydaddyo
    I was just kidding. :D
    My Hal head is on a B block. The head needs some welding, That is the hold up.
  20. My Winfield "Yellow Head" was just welded up by Midwest Cylinder Head in Nevada, IA. Sent it off the Friday before Thanksgiving and got it back Wednesday - pretty dang fast. Had a crack on the water outlet 'backbone' about 6" behind the Winfield script and another between water passages on the mating surface - you'd never know it was ever cracked, perfect repair. I highly recommend them.
  21. Crazydaddyo
    Crazydaddyo
    This is how I spent my week end:
  22. Crazydaddyo
    Crazydaddyo
    Thanks for the info, but I think I'll find someone here is So. Cal. I don't want to ship this head too far from home.
  23. BCCHOPIT
    BCCHOPIT
    Very Nice!!!!
    The A block I am running now I took to much off the top right of the port and found water :(
    Live in learn....
  24. Crazydaddyo
    Crazydaddyo
    How did you fix it?
  25. Crazydaddyo
    That looks great, its a lot of work and messy I had my share of chips down my shirt and in the hair too.
    You need one of them CNC porting machines LOL
    I have several programs now that I rough mill and then finish by hand that way I have a little giude line to blend to I guess its cheeting a little but seems to work for me.
    What are you running for intake and exhaust valves?
    Bill
  26. brjnelson
    brjnelson
  27. Crazydaddyo
    Crazydaddyo
    Thanks Bill,
    Despite proper safety equipment, I am still blowing cast iron filled snot out of my nose.
    Intake valves are cut down 1.94" SBC valves shaped and swirl polished. exhaust is stock size modern valves shaped and swirl polished too.
    I have a CNC machining center at work, but It would have taken more time to develop, write a program, set up, and cut the ports then it did to do it by hand. I'm sure you know that!!!!! I, just don't do enough to justify all that work.
  28. Crazydaddyo
    Crazydaddyo
    I like it, I'm thinking of setting up my sedan with a Winfield red head and Winfield BB down draft.
    What size SR's are you running?
    What Distributor are you running that has a mechanical tach drive?
  29. brjnelson
    brjnelson
    The carbs are dual "AA" with a adapter choking them to a Stromberg base.
    I took them off and put on 2 81's and got my fastest times and the Iowa hillclimb this year.
    The carb is now looking good on Jason "Elrod" 's coupe.
    The Mallory is a tach drive for a MGB that I machined down to fit my A about 15 years ago. I will try to find a part number & photo some time.
  30. Very nice! What are the specs on the cam? I dig the Rex-A-Co gauges...I'm thinking about running a set too.
