Hot Rods The Cornfield Streamliner build
Discussion in 'The Hokey Ass Message Board' started by cornfieldcustoms, Sep 8, 2018.
  1. cornfieldcustoms
    cornfieldcustoms
    Sorry for the slow progress, since Detroit I have been busy with customer work.
    I have been doing some parts design and getting some of the steering parts machined. I needed a good way to get the steering from the center of the car in cockpit, to the outside of the chassis and run up front. So I designed a chain drive steer clear set up. Finally got the firewall cut, and everything assembled. Still need to put the tensioner adjuster bolt on there. But it’s looking like something. 7AE92C6F-BA3D-4F5D-A42D-5617E4B6CDB5.jpeg ADF04C91-D3D3-4814-B89C-C5A9ACF935CC.jpeg
  2. Jethro
    Jethro
    Nicely done!
    loudbang and 41 GMC K-18 like this.
  3. fresh hops
    fresh hops
    Nice work! very clean, tidy and the bearing hubs for the sprockets are cool looking as well.
  4. jimmy six
    jimmy six
    Looks great, remember the inspector will move the steering wheel to see the action of the front wheels. When I was doing it I wanted to see slight movement of a tire without moving the wheel much. I was never looking to see how sensitive it was just some movement. Slower steering always seemed to help drivability keep; up the nice work.
  5. cornfieldcustoms
    cornfieldcustoms
    yep i always check for movement and no slop I from wheel to tires in the tech line. The good thing is if I need it to speed up a little I can correct it with the the gearing.
    when laying out the steering I was talking with kiwi Paul and be recommended putting a reduction box in line to slow the steering down .so it’s hard to over correct at speed. The reducer I went with is a 2:1
    chryslerfan55, Tman, loudbang and 2 others like this.
  6. cornfieldcustoms
    cornfieldcustoms
    Got all the tensioner parts made and installed. Almost ready to get the firewall tacked in the chassis
    49CA7E02-2F53-433D-9328-A51639685282.jpeg 6E4B9A47-EE3B-490C-A64B-71F20D20CCA5.jpeg 14DBAC7E-CA41-4677-AA60-7F8C24530A2F.jpeg CB7AC924-86AD-4819-AD2C-3F60875C1824.jpeg 84E4666B-29D6-4627-B72F-3ECD25BA934E.jpeg 427D587E-5A4C-4A48-8C89-C98E50442C5D.jpeg 3BAFEF5A-6932-4CDF-82C9-FE3BF75B5365.jpeg 4251F1C5-45E3-40DC-91B5-7D263A9C5369.jpeg C1FD5869-3232-498A-90B1-DC4A859256C1.jpeg
  7. sliceddeuce
    sliceddeuce
    Very nice.
    Stogy likes this.
  8. Just “wow!”. Nothing else to say.
  9. gary kessler 1932
    gary kessler 1932
    When are you going to learn how to weld??? just kidding beautiful work!!!!
    Stogy and loudbang like this.
  10. 1-SHOT
    1-SHOT
    Outstanding
    Stogy, chryslerfan55 and loudbang like this.
  11. cornfieldcustoms
    cornfieldcustoms
    So have been making a little more progress on the streamliner. Been working on getting the wheels built, wheels and tires on, more things gusseted, and finish up some little things. As of now the plan is to have it on the ground for the first time on July 11. Then have it at speed week for its first pre inspection on work so far 1274C2FF-8C21-411D-82C3-5D86C60EC403.jpeg 1F316381-B3BB-4E1E-A5A9-2BFFFF03C00C.jpeg 58C40499-EEE5-421F-9E98-4DAC0463ED16.jpeg A6B9E34C-8DEA-47F3-B24D-4C79AF0E26F7.jpeg BCD3FAEA-28DD-4119-AA6E-2AB6F6453655.jpeg 65FC2BEA-8C01-49CD-B821-011602885FD9.jpeg D17B0EC1-F050-4B43-816D-DE7FED7B700E.jpeg 0069D6B0-E10F-43EA-9D5F-AC54BCBA1CA0.jpeg BFE1D582-2F10-4CED-9803-3DDEADB54342.jpeg 3CE3B0F6-EF43-46B8-8F90-3A16640072A7.jpeg
  12. I REALLY like all of your extra tubes in the cage area. Beautiful and stout.
  13. cornfieldcustoms
    cornfieldcustoms
    Thanks man. I wanted it to be over built for the record I am chasing. Since I am sure I will want to go faster
  14. cornfieldcustoms
    cornfieldcustoms
    Put the car on the ground today! All suspension works, car steers. Working now on lift cylinder mounts, rear bump stops, seat, and floors A8BEB558-0335-4493-9C61-DC9866A008AC.jpeg A3ECC75E-57D1-42D9-B26C-6369C23017D2.jpeg 499B53A9-F734-4706-88AD-962794BA8921.jpeg 785049C7-10DA-4D08-81F8-57BDA296DA75.jpeg 9ECC4E72-B08A-454F-A4F9-260E1E46A14F.jpeg
  15. The37Kid
    The37Kid
    Looks great! I've been a big fan of "Redhead" ever since the Hot Rod cover shot back in the 1960's. Now that your car is on the ground could you jack up one front wheel so we can understand how the shocks work? Bob
    chryslerfan55, loudbang and Tman like this.
  16. Hope to see it there. Up in the air on the trip tho
  17. Flipper
    Flipper
    from Kentucky
    F*ck yeah! That is all I have to add.
  18. mkebaird
    mkebaird
    1st class build. Good luck with your inspection.
    JC Sparks and loudbang like this.
  19. BEAUTIFUL!!
    Eric Rickman photo.
    Phil
    The 39 guy, Stogy, The37Kid and 5 others like this.
  21. cornfieldcustoms
    cornfieldcustoms
    A few more progress shots from over the weekend. Got the rear adjustable bump stops made and tacked in, seat being designed and fabrication started, temporary steering in until I get the tilt column built, front lift cylinders tacked in, and decided to run and old breathing o2 bottle for the fuel tank up front B758CBEE-D8FA-49E4-AC33-11973C868513.jpeg D31FC124-B4DC-4286-8C6B-3F615F7A40C1.jpeg 025E5B3A-BDC8-4902-849D-70265B55DD37.jpeg C63C8B8C-29E3-413C-8D27-BF54A38F6F51.jpeg B11718BF-9EF1-467C-9C63-7E9F9ABE420B.jpeg CDB92AF2-068D-4359-9859-E78E60232E75.jpeg
    brEad, The 39 guy, bchctybob and 13 others like this.
  22. krusty40
    krusty40
    What a wonderful build. Don't forget the many gussets (I prefer tubular rather than plate) you'll need on your roll cage. Lots more coping in your future.
  23. View attachment 4752850
    explain that to me... is that a front mounted crank driven supercharger? I have never seen anything like that, although it makes sense from a height perspective. What do these types of cars run for tranny? Or is it something more exotic than conventional.
    I have always drooled over these cars, but never even seen one in person.
    loudbang, Stogy and chryslerfan55 like this.
  24. You are correct. A number of very quick cars ran them back in the 50s.
  25. cornfieldcustoms
    cornfieldcustoms
    I am well aware. I have some of them made up already just not on the car yet. Waiting to get it looked over before I put them in. I am doing 180 wrap around gussets so I will have to weld those bars in solid first. 99502720-0BDC-4AE0-8FCA-831155BC7172.jpeg
  26. Thats a Potvin supercharger. Most of the modern cars run some form of high end racing tranny suck as Lenco, Jerico, Liberty and the NASCAR Tex versions of a muncie.
  27. Ebbsspeed
    Ebbsspeed
    The bearing hubs on your chain steering setup, what are they from? The spindles on my Kubota mower deck look very similar.
    Your design and execution are amazing!
  28. cornfieldcustoms
    cornfieldcustoms
    i custom designed them and had them CNC machined for this application
    loudbang, dana barlow and Stogy like this.
  29.
  30. RichFox
    RichFox
    We use a B&J transmission. Much like a Lenco but more Bonneville car friendly.
    chryslerfan55 and kidcampbell71 like this.
