Projects The 49' Ford Roadster Project
Discussion in 'The Hokey Ass Message Board' started by rottenleonard, Jan 8, 2017.
  1. rottenleonard
    rottenleonard
    I'm in need of a decent front bumper and a radio or just a radio delete plate
  2. rottenleonard
    rottenleonard
    Also i have the roof window regulators and rear glass if anyone can use it pm me 20161107_102902.jpg
  3. Toqwik
    Toqwik
  4. butch27
    butch27
    Great work. I love it.
  5. fast30coupe
    fast30coupe
    from Illinois
    Looks good the contours of those work
    Good to fill a model a coupe roof in.
  6. Looks good. Did you add any extra support in the body to keep if from splaying now that the roof is removed?
  7. rottenleonard
    rottenleonard
    While it was cross braced, i filled the window channels, then i spot welded the pannels in that the window regulators mounted to. This formed a rather large sheetmetal box that made it pretty rigid. I'm sure it isn't side impact rated but I'll bet it isn't a whole lot different than it was before.
    lothiandon1940 likes this.
  8. Bugguts
    Bugguts
    I like it!
    I was thinking not when I saw the tape cut lines, but, dang! You pulled it off. Going to be fun when it warms up.
    Only 151 days till summer!
  9. rottenleonard
    rottenleonard
    Haha yeah you should have seen my hired hands face when this started happening. I didn't tell him my plans just come out of the office and started laying tape, bracing and went after it with the saws all and cutoff wheels. He was pretty wide eyed when i called him over to help lift the top off. Priceless!
    falcongeorge and lothiandon1940 like this.
  10. Awesome story. Thanks so much for sharing. Love the result.
  11. Nice vision and execution!
  12. Latigo
    Latigo
    Great project. That will be a fun one.
  13. Engine man
    Engine man
    from Wisconsin
    You knocked a good chunk of ugly off it. I don't think it's possible to get it all.
    OahuEli likes this.
  14. rottenleonard
    rottenleonard
    On the front of the cowl there are some legs that reach forward about a foot and attach to the frame, one of these had cracked and broke off this causes a severe 20170117_141551.jpg sag in the door. Also someone had broke off the mounting bolt in the frame. After digging out the bolt the leg was cut off square.
    You can see the mock up steps in getting the right shape for the foot.
    Once i had the shape right i cut,folded and welded the replacement piece. The outer shell holds a piece of 10 gauge in the bottom as a stiffener.
    This was welded on using a square of 3/4" plywood as a spacer to keep everything square.
    And a reinforcement piece was welded to the outside to make sure it never happens again. 20170118_110515.jpg
  15. CBurne7
    CBurne7
    All the So Cal guys are probably like, "uhh... so what. I drive a roadster around all year."
    CoolYourJets likes this.
  16. greaser
    greaser
    Great vision and follow through.
    Forget the bumper and fab up a rolled pan.
  17. Anything exciting on the mechanical side? Friend in high school (59 or 60) had one with a Yblock. Honked.
    geoscot49 likes this.
  18. rottenleonard
    rottenleonard
    It's all stock on the running gear, good running flatty with a 2 pot, 3 on the tree.
  19. rottenleonard
    rottenleonard
    The trunk striker was missing, i couldn't even find a picture of one on the interweb so i just kind of winged it. Works like a charm! 20170127_130821.jpg
    The trunk lid was sticking out from the body about 3/8" at tge bottom but at the top the gap couldn't have been better so it took a little influencing.
    Got it fitting pretty nice.
    Working on the punch list and waiting for a warm day.
    Tim, mgtstumpy, oneratfink57 and 2 others like this.
  20. Nice one Robert,
    Hope you and yours are all good?
    Look forward to seeing the completed car.
  21. rottenleonard
    rottenleonard
    Hey Allen, things are good on my end, going too many directions so everything is normal....i probably won't go a lot further on this car it was really an unintentional project and I should be doing other things. I'll probably get the very last little bits of rust out of the doors and get everything functional and someone can have a fun driving project car. The flatty needs hopped up and a T5 would be sweet but i have 3 other cars in the works right now.
  22. rottenleonard
    rottenleonard
    Any X-spurts on here? This is the bumper it came with, it looks like stock mounting but the contour is all wrong. Mayby a later model bumper?
  23. funeral
    funeral
    from Phoenix
    Great build. I want to do that to my 50 merc four door
  24. 208custom
    208custom
    Kind of looks like a rear bumper to me, but I would be a little surprised to find that it mounts right up to the front brackets?
    Cincinnati Slim likes this.
  25. That looks like a fun car now that you made the changes. Nice vision. My only suggestion is a little more altitude adjustment on the suspension.
  26. steinauge
    steinauge
    from 1960
    I have a stock radio for one of those.If you will pay the shipping its yours if you want it.
  27. rottenleonard
    rottenleonard
    Super generous offer man! Thanks. I did however make up a delete plate of sorts.
    Bent up some aluminum.
    I had bought some parts from HAMB member Chubbie, and he threw in lots of extras including two extra dash knobs. I was able to thread the backs of them to make retainers for the delete plates.
    And used those with 3/8 nuts to hold in the delete plate that was painted with hammertone.
    mgtstumpy, ravedodger and koolkemp like this.
  28. Hot Rods Ta Hell
    Hot Rods Ta Hell
    Terrific vision and great work on the Shoebox! Looks like most of it was done with very little in parts, which demonstrates just how much can be accomplished on a project with just your labor investment.
    The car now sits poised as a great starting point for the next owner to take it to the next level.
    If that owner was me, I would;
    • Chop the windshield and fit a lift off Carson style top.
    • Open up the door channels so they had functioning roll up glass.
    • Slide in quarter windows.
    • French the headlights
    • WWW's
    Later mods could include rounded hood corners and a full custom grille treatment, etc.
    The stock roof skin could be used to fab a lift off hardtop, so maybe hold off on selling it until the car is sold so the buyer has first shot at it. It would be cool to do a lift off top that was not padded, but rather painted to match the body. The ultimate lift off top would be a roof from a Vicky. You could roll in a chopped Vicky or open car.
  29. rottenleonard
    rottenleonard
    Thanks, it's cool to hear when something is gone far enought to make people start seeing ideas for how they would finish it. On the top and side windows I'm not sure i would put that effort in it as everyone I know with a rag top acts like you just spit on their shoes if you suggest putting the top up like it would be sacrilege. Instead i just went for a waterproof interior, where you don't have to stress if you get a little liquid sunshine on a trip.
    I do like your ideas of www and the french headlights. I think if I were to finish the car entirely i would add a T5, and a couple more carbs, maybe update the front suspension and brakes. I decided the front bumper looks better in the scrap pile and have been fighting the urge to pick up some stainless and start forming one like what I see in my head. This would be such a fun touring car...... too many projects better stay focused......
