Projects The 394 B -32 ford 3W
Discussion in 'Traditional Hot Rods' started by hotrodderhaag, Feb 14, 2016.
  1. hotrodderhaag
    hotrodderhaag
    Not alot of progress to post. I've been just cleaning small parts, and getting things ready to assemble.. picked up a super clean model T spring for the back. I started blasting and getting the backing plates ready for paint and assembly . doing every little bit I can until my body is done at Flops. I took my 40 wheels to several places getting prices on blasting and powder coating.. quotes of $400+ drove me to just using aircraft stripper from work, then soda blasting them in the cabinet. I saw the black paint falling off, and underneath was a bright metallic purple with cream colored pin stripes... sure makes you wonder what these ol wheels have been on and where they have traveled.
    DylanHill1931 and kidcampbell71 like this.
  2. hotrodderhaag
    hotrodderhaag
    I started soda blasting wheels. these things really cleaned up well!
    DylanHill1931 likes this.
  3. Retro61
    Retro61
    Soda works good, I've Blasted a bunch of Wheels!
  4. 3banjos
    3banjos
    from NZ
    Liking your vision Ben. Liking it a lot. When my brothers 7.50 x 16's for his roadster turned up I freaked. They're a bloody tall skinny tyre when off the rim. Certainly fill that wheel well nicely. All the best.
    hotrodderhaag likes this.
  5. I'm in for the ride
    jimz31 likes this.
  6. hotrodderhaag
    hotrodderhaag
    worked on the rear end today. I primed the backing plates and grease sheilds. soda blasted all the hardware and bolted them on the quick change rear. last thing to do is get the rear hubs separated from the old drums. I'll be pressing new studs into the hubs so the rear drum is removable. I've seen this done before so I'll have to research what studs were used. I'll be reusing the original ford rear wheel bearings. they are very nice .
    received_230981653911703.jpeg received_230981650578370.jpeg received_230981647245037.jpeg received_230981860578349.jpeg received_230981640578371.jpeg
    DylanHill1931 and Tim_with_a_T like this.
  7. bostonhemi
    bostonhemi
    Love them parts. Fantastic project.
  8. I used the Pure hotrod rear shock mounts for my quickie and really like the way they look. You can use the bolt on ones. I had to weld the rear mounting brackets on mine because I have late model plug in axles. They look great with the quickie.
  9. hotrodderhaag
    hotrodderhaag
    would you happen to be able to post any photos ? I was gonna run mechanical shocks , but I prefer gas shocks .
  10. Tim_with_a_T
    Tim_with_a_T
    I love your quickchange and the use of all early parts. I've been on the fence for years trying to decide which route to go on the next project, which I feel needs a quickchange. Your documentation helped solidify my decision, so thank you!
    Sent from my SM-G900V using H.A.M.B. mobile app
  11. hotrodderhaag
    hotrodderhaag
    a little early ford adaptation.... i used a Dorman wheel stud, part# 982821. reamed the stud holes to .620, flipped the hub over and removed a little material to let the studs sit flat. they pressed right in nice and tight and have long enough of a knurl to fill the hub. the new aftermarket drums are hub pilot , not stud pilot.. so they center themselves on the center of the hub. best part is, any autozone carries them and can be changed alongside the road!.
    these studs are intended for a 1990 chevy astro van... so if my wheels fall off, I'm blaming it on that.
    12810084_231400007203201_1468181385_o.jpg 12789880_231400017203200_49242570_o.jpg 12787048_231400020536533_1608543048_o.jpg
  12. continentaljohn
    continentaljohn
    Awesome build and thanks for the wheel stud number
  13. JimmyD3234
    JimmyD3234
    from PA
    love that chop its going be - BAD - ASS - good luck :cool::cool:
  14. Southfork
    Southfork
    Where'd you source that louvered deck lid? Did a single vendor provide it already louvered for you, or did you have to buy the deck lid from one vendor and then send it to be louvered somewhere else?
    chambies and hotrodderhaag like this.
  15. hotrodderhaag
    hotrodderhaag
    actually it came from Brookville this way... apparently they had several done by SAR, (Steves auto restoration) and I just had to ask the right questions to get it.
    manx4me likes this.
  16. Yes I could. I have been holding out posting pics of my almost finished frame but here is a teaser pic or two. Left and right shown. If you have early Ford axle tubes you can run the bolt on ones. I'm running 72 Bronco brakes with plug in axles to handle my 371 Olds so I had to get the weld on tabs/bracket mount. Very happy with this product. I did have to use a short P&J shock to get it to work with my setup. Hope this helps. rear shock mounts 001.JPG rear shock mounts 002.JPG rear shock mounts 002.JPG
  17. Larry Pearsall
    Larry Pearsall
    Great build pics. I knew I was not the only one with car parts stashed in the bed room.. I'm ready to see the body mounted..
    Low Beam likes this.
  18. hasty
    hasty
    Will be following along with your build - hope it goes well
  19. hotrodderhaag
    hotrodderhaag
    a little confusion on the wheel stud. I got them from advanced auto parts . here is a screen shot of what I got. the actual dorman number is 610-126 according to summit racing, autozone or advanced auto couldnt look them up that way. so we went with that they were inteded for, a 1990 chevy astro van with a 4.3
  20. Gotgas
    Gotgas
    from DFW USA
    I was wondering about that. I believe an Astro van would have had a 7/16" stud, not a typical Ford 1/2".
    So I just wrote that up so I could subscribe to the thread. :D Nice work so far!
  21. hotrodderhaag
    hotrodderhaag
    the astro van does have 1/2x20.. the stud i purchased is for the astro van and chrysler used them also, the auto parts store all use their own part numbers . so that factory dorman # is 610-126.
    Gotgas likes this.
  22. DAM! Ben this is looking good.......I know this is going to turn out KILLER. Have you checked out my build lately as I am winding it up. We would look good running together in them. Sure wish I had that deck lid of yours. Got a color in mind yet?
    Signed up for the ride on this build.
  23. hotrodderhaag
    hotrodderhaag
    I have fallowed yours since the day you scored that body !!! when I decided to build mine , I knew first thing it had to be everything I ever wanted in a hot rod. since a project like this, usually only gets to happen 1 time. I love how your car turned out. love the color too. I decided to go with a factory 32 color, Tunis grey. black wheels and I'm going to light cream colored pin stripes on the wheels. then it'll have the 394 B on the door just as it was intended for my 34 3 window when I did it. I have formed my entire build around how Ken and Keith build the rolling bones cars
  24. Love your color choice..... How did you come up with the 394 B ? as I just know there has to be a story on that.
  25. hotrodderhaag
    hotrodderhaag
    I bought a hood for my old 34, that was off a dirt track car. it had a 394 Olds in it apparently and they had painted on the hood ," 394 olds", down the sides . and I just though it was cool as it gets . so it has stuck with me, the 34 was 394C , but it got sent to a new home , so the 32 will be 394B.
  26. edwardlloyd
    edwardlloyd
    from Germany
    Subscribed. Looks like this will be a good one! Like the progress so far.
  27. hotrodderhaag
    hotrodderhaag
    here is a small update. Finished up the rear hubs, The studs leave a nice bit of knurl sticking out that will also help center the drum. Really happy with how they turned out,. I etch primed the 40 ford wheels, and they are ready for fill prime now.. Then a nice thick coat of black. Doing what small jobs i can in between a few customer cars..
    12524351_235019160174619_2037065883211221182_n.jpg 12795320_235019913507877_4745942544304165224_n.jpg 12802975_235591036784098_4086241720771495563_n.jpg
  28. hotrodderhaag
    hotrodderhaag
    just a few photos of all 4 wheels.. also you can see the rest of my 32 slung from the rafters. there is a 32 chassis, boxing plates, 36 radius rods, 32 wishbone , 32 heavy axle , t rear spring , posi front spring , 39 ford x member with pedals, 32 headlight bar, 32 dash , and 4 new excelsior tires. all waiting there turn.... and my other pride and joy, my future belly tank project ..
    [​IMG][​IMG][​IMG]
    Sent from my SM-N900V using H.A.M.B. mobile app
  29. hotrodderhaag
    hotrodderhaag
  30. Ben,.
    Do you have the rest of the rear brake parts for this? I have some nice drums and other parts left over.
