Projects the '27 Roadster saga
Discussion in 'Traditional Hot Rods' started by Paul, Jul 20, 2010.
  1. Paul
    Paul
    Editor
    wet paint assembly
    brEad, Drewfus, dubie and 8 others like this.
  2. 1-SHOT
    1-SHOT
    Looking good.
    Paul likes this.
  3. At this rate you will be driving it in a week ! :D JW
    Paul likes this.
  4. Gary Addcox
    Gary Addcox
    I have been accused of overkilling mounts and brackets, but here I go. I really feel the tube needs a small gusset front and rear to take the strain off the weld joint. I have been told that that particular joint is brittle and requires a bit of gusseting. Really like your build.
    Paul likes this.
  5. Gary Addcox
    Gary Addcox
    Paul likes this.
  6. Gary Addcox
    Gary Addcox
    Man, you are some kind of Craftsman. It is so enjoyable to watch a true wizard do his thing.
    Paul likes this.
  7. Gary Addcox
    Gary Addcox
    Is your T touring going to be Olds powered ? You must be related to Ransom E. ! ! Your work is above board. Your metalsmithing is excellent. I've read your posts for as long as I have been a HAMBer, but I had no idea you were so talented. Are you going to T.R.O.G.? Hope so.
    Paul likes this.
  8. Paul
    Paul
    Editor
    thanks Gary, you are too kind.
    especially when you see some of the work of the real masters here.
    no plan for the touring yet,
    but yes if something get's built of it it'll likely get an Olds,
    no sense going out and buying something else, with all this iron around.
    West Coast TROG?
    sounds like a lot of fun
  9. Gary Addcox
    Gary Addcox
    Paul, there is a young gun who works for Austin Speed Shop and he reminds me of you. His name is Eric Anderson, but I don't recall his avatar name. He built a '24 T roadster with Olds power. I think he watched a DVD by Ron Covell, then proceeded to build a new turtledeck that looks like Henry stamped one, then sent it to him. Currently, I think he is driving an Olds coupe around the world. When he returns to A.S.S., he will start new projects and exhibit his talent once again. Keep up the superior work, and we HAMBers will be watching in awe.
    kiwijeff, kidcampbell71 and Paul like this.
  10. He's @Anderson on here. And here's a link to the build thread of his Olds powered T: http://www.jalopyjournal.com/forum/threads/24-t-roadster-build.727893/
    He sold it recently and bought a deuce, but the car was also featured in Hop One one or two issues ago. In my opinion, it's a killer car, and I agree with the talent comments.
  11. bengeltiger
    bengeltiger
    x2. Great job on the build. The pic with all the engines looks like @jckc 's garage except all Chevies here in KC.
  12. Paul
    Paul
    Editor
    judging by Eric's pictures he far exceeds my skill level by a long shot
    was great that he posted pictures of his builds.
    hope he doesn't delete all of them, the T pictures were very inspiring.
  13. Paul
    Paul
    Editor
    been a little preoccupied last few days,
    only an hour or so a day here and there.
    got a few things cleaned up, painted and bolted together
    and ordered a couple small parts..
  14. Paul
    Paul
    Editor
    'ordered a Bob Drake U joint Saturday and it was on the door step this morning,
    I did have to modify it to fit though,
    the modified LaSalle output shaft has a shorter splined section than the stock Ford
    so I took the U joint apart and clamped the half needing massaging in a drill press vice,
    put a small grinding stone in the drill press and relieved about a quarter inch of spline from the U joint.
    put it back together
    and bolted the engine and transmission in for real,
    no more mock up, with the chassis anyway.
    and rolled it outside for a glamor shot..
    brEad, Squablow, mad mechanic and 8 others like this.
  15. Lookin' great!
    falcongeorge and Paul like this.
  16. Paul
    Paul
    Editor
    'wasn't going to but..
    I'm going to rattle can the body..
    just a light coat to make it all one color so I can see what I got..
    it'll save me hundreds of dollars and at least a month's time.. if not years..
    and look like crap..
    but I could be driving in a week...dammit
    brEad, cactus1, bct and 1 other person like this.
  17. RainierHooker
    RainierHooker
    from Tacoma, WA
    Looks outstanding Paul.
    Paul likes this.
  18. Paul
    Paul
    Editor
    Spray can primer..
    What's next? Brushed top coat??
    oh the humanity
    brEad, AHotRod, kiwijeff and 12 others like this.
  19. F&J
    F&J
    I am prime/fill/sanding pits today on the last few small pieces... 992 degrees, 312% dew point index...
    oh the humidity
    I wanted the car to have color, not primer... but not sure it's worth it right now
    Paul likes this.
  20. rjgideon
    rjgideon
    After building a beautiful chassis like that, I think you deserve to have some fun with it. Well done, Paul!
    Paul likes this.
  21. bengeltiger
    bengeltiger
    Looks great in primer - now drive the cr@p out of it!
    hendelec and Paul like this.
  22. Paul
    Paul
    Editor
    lots of little stuff in and done
    lots of little stuff yet to do
    but making steady progress
    brEad, AHotRod, Tuck and 7 others like this.
  23. F&J
    F&J
    the gauges have returned. I forgot about them.
    Paul likes this.
  24. Paul
    Paul
    Editor
    Yes, 1937 Chevrolet truck gauges and 1935 Chevrolet car clock.
    I tried to make the clock work but it was not cooperative so I replaced the stock clockwork with a quarts unit.
    None of the others are hooked up yet
    and the temp will need a new bulb and tube.. got one around here somewhere...
    Tim_with_a_T likes this.
  25. Wow! Just wow.....
    Jay
    Paul likes this.
  26. greaser
    greaser
    Paul, you do incredible work. The proportions on this little roadster are perfect. I get excited at every new post!
    I went back thru this thread looking for tire sizes, and didn't see the info. What sizes are they?? (Beat ya to it Larry!)
    Paul and kidcampbell71 like this.
  27. Paul
    Paul
    Editor
    thanks greaser,
    tires are 8.90-16 and 5.00-16 Firestone dirt track through Coker,
    I think I went with a 7" rim on the back and 5" on the front.. been so long I forget
    greaser likes this.
  28. Paul
    Paul
    Editor
    mounted voltage regulator, fuel pressure regulator and fuel block,
    pulled the master cylinder apart and moved the residual valve and it's rubber ring from left bore to right
    and bolted it in too.
    mounted windshield stanchions and frame, still need to get some setting tape to set the glass in the frame.
    fit the column drop
    and painted a few more bits and pieces.
    brEad, AHotRod, Tuck and 6 others like this.
  29. Dirty Dug
    Dirty Dug
    Great work Paul. You really nailed it.
    Paul likes this.
  30. onekoolkat1950
    onekoolkat1950
    Paul likes this.
