Features The 1955-1956 Plymouth and Dodge Thread
Discussion in 'The Hokey Ass Message Board' started by MrBelvedere2, Feb 12, 2009.
  1. I have a request/question of anybody who may have access to parts off of a '55 Dodge Lancer (preferably a two door, but not critical). I'm in need of a full set of stainless trim strips that go down the side of the body. These are to fit on my '49 Ford Coupe... (second picture).. Thanks for your time.. will pay well....
    Here is my full website at this link:https://49fordcoupe.smugmug.com/
    Here is a picture of the model car showing the trim strips:https://49fordcoupe.smugmug.com/The-Car/i-qCkWgKp/A
    Here is a picture of how it mounts/looks on my "original '49" taken in 1961..:https://49fordcoupe.smugmug.com/The-Car/i-FKNkHwX/A
    Thanks for your time.. If you might know of somebody else who may have these, please forward this email to them...
    Paul Gerdes
    Austin, Texas
    512.689.7713
  2. George
    George
    try the www.forwardlook.net if no one comes through.
  3. Thanks... awaiting response from a couple of yards that some guys have suggested..
  4. George
    George
    Big M by some chance?
  5. tailfins
    tailfins
    from calif
    WANT pair door glass frames with good chrome for my 56 coronet hardtop coupe..also need same pair for my 57 royal hardtop 2 door
  6. Hemihead_NHRA
    Hemihead_NHRA
    Hey does anyone have a picture of a ‘56 coronet dashboard thats lit up at night? Im trying to figure out what it looks like
  7. Old Ray
    Old Ray
    No, but if anyone would 56D500boy (Dave) over at the http://www.forwardlook.net/forums would.
    I can't get the link to work (old guy)but that should get you close.
  8. Aaron Macdonald
    Aaron Macdonald
    Hi Guys, new to this forum but have been snooping around it for years! got a 56 Dodge Kingsway thats under the knife, was badly modified in the past and a long way from original so not worth restoring so i am resto modding it , have a series 3 jag front end under it and a Ford explorer 8.8 in the rear , running a 5.3 LM7 & th400 ( a hemi would have been nice but are crazy money down here in NZ!) am currently tackling some rusty sills with some 1970s repairs with pop riveted & brazed panels straight over the original rusty sills! anyway so since im unpicking around the "B" pillars im wondering how this would look as a 2 door , can anyone tell me what the door length is on a 2 door one of these? cheers
  9. Jalopy Joker
    Jalopy Joker
  10. Judging by the LHD and door length thats been made from a US 2 dr, but still a neat job........andyd.
  11. ColDry
    ColDry
    Hi Aaron
    I've seen a 2-door conversion done in NZ before. The cars a red Plymouth Savoy down Morrinsville way. I can put you in touch with the old owner who had the modification done if you like? I have plenty of parts if you need them too (spare parts car plus a whole lot more). I'm in Auckland. coldry@orcon.net.nz.
    Colin
  12. Aaron Macdonald
    Aaron Macdonald
    by chance could you tell me the length of your doors? cheers
  13. Hemihead_NHRA
    Hemihead_NHRA
    I have a question about the 55-56 dodge 3 speed manual transmissions. I currently have a 56 coronet with a powerflite; and I know that they are good transmissions, but they are heavier than the standard. Im looking to swap the powerflite out for the manual to help save a little weight. Id rather not buy an adapter and get something that would bolt up and be slightly better. And for whatever reason I cannot find the transmission code for the 3 speed. [​IMG]Or if there are any 60-70s 3 speeds that might just bolt up. The goal for the car is essentially; think of the “Paint it Black and Hit the Track” build HRG did, if you havent seen it they have a short summary of the episode on YT. I basically want to do that but with all 50s mopar parts
  14. George
    George
    6 or 8? either way on the 8, and probably the 6, you can use trannys up to '61 for similar engine. '62 & up has bell and crank changes. Q.E.C . (73RR here on the board) has adaptors for the 6 & 8 to use post '61 A/Ts. Sticks probably Wil-Cap or Hot Heads for adaptors.
    Hemihead_NHRA likes this.
  15. Hemihead_NHRA
    Hemihead_NHRA
    It is a 270 poly V8, thanks for the info. Do you know what the transmission codes would have been for the 55-60’s 3 speeds? IMG_0981.JPG
  16. George
    George
    No. You can use any tranny behind a hemi, hemi based Poly(that's what you have), or "A" Poly up through the '61 model year, should be out there! . The PF is a 2 speed, to us a modern A/T you'd have to use the S. B. 727 3 speed, would be an improvement over the PF.
  17. uncleandy 65
    uncleandy 65
  18. uncleandy 65
    uncleandy 65
  19. uncleandy 65
    uncleandy 65
  20. uncleandy 65
    uncleandy 65
  21. uncleandy 65
    uncleandy 65
  22. uncleandy 65
    uncleandy 65
  23. uncleandy 65
    uncleandy 65
  24. uncleandy 65
    uncleandy 65
  25. uncleandy 65
    uncleandy 65
  26. Sooooo wrong on an otherwise nice......the antenna should go in the back.....duals preferred.......
    LOST ANGEL likes this.
  27. uncleandy 65
    uncleandy 65
    The owner spent all his money on the fancy wire wheels and didn't have any left for the twin antenna's on the back.
  28. uncleandy 65
    uncleandy 65
  29. uncleandy 65
    uncleandy 65
  30. 565758 fury plymouth
    from texas
