th350 tail housing ??
Discussion in 'The Hokey Ass Message Board' started by sewanhaka62, Apr 4, 2012.
  1. sewanhaka62
    sewanhaka62
    hi on a chevy th350 - - can you use a same length tail housing from a
    buick/olds/pontaic or th350c .. are speedometer hookups/hole the same
    .. thanks bob
  2. there are 3 different tailhousing lengths, they only interchange if you swap the actual tailshaft as well, but a BOP short tail will fit a chevy etc I do believe.
  3. squirrel
    the speedo hole on the BOP transmissions is usually the large size (same as the 700R4), so you need a different gearset and sleeve
