th350 shift points
Discussion in 'The Hokey Ass Message Board' started by goldflake, Jul 10, 2011.
  1. goldflake
    goldflake
    have a question for you all....I have a th350 tans and it shifts little late, I know I can corect it from the vacum modulator but what direction does it make it shift sooner....thx all
  2. squirrel
    counterclockwise....??? that's just a guess, you're loosening the screw which relaxes the spring and makes it easier for vacuum to move the diaphragm, so it will think there's less load on the engine and shift sooner.
    If that doesn't work, turn it the other way. Or play with the governor. or fix the vacuum leak. etc
