TH350 leaking?
Discussion in 'The Hokey Ass Message Board' started by mack57, Jul 27, 2014.
  1. mack57
    mack57
    Hey All,
    Th350, approx '84, leaking from speedo cable. Replaced "O" ring & still leaking pretty well. What else can be done?
  2. I went to the parts house and found a fatter "O" ring and used it on the 350 and it doesn't leak anymore. HRP
  3. squirrel
    The sleeve that the gear rides in could be worn out, if it's the pot metal version. The seal inside the sleeve could be worn out. The driven gear could be worn out where the seal rides on it, or even where it rides in the sleeve.
    saltflats likes this.
  4. mack57
    mack57
    Thank you guys!
  5. saltflats
    saltflats
    from Missouri
    On the seal that goes on the driven speedo gear you can double them up on some of the gear holders.
  6. These usually have a small leak between the driven gear and the driven gear housing. Other than the O-ring, there isn't anything else to keep fluid from leaking out. I doubled the O-ring in one I had once and that seems to work. The O-ring wouldn't bind up due to the trans fluid keeping it lubricated.
