Technical th350 kickdown cable help
Discussion in 'The Hokey Ass Message Board' started by 49ChevTruck, May 4, 2016.
  1. My lokar kickdown cable arrived today so I got it hooked up as the instructions.went out for a drive but still no kickdown...Any ideas?
  2. 56sedandelivery
    56sedandelivery
    What engine? There may not be enough "throw" on the arm of the carburetor.
    I am Butch/56sedandelivery.
  3. olscrounger
    olscrounger
    ck carb at full throttle-then ck pull on cable and see if there is any more pull on it at this point.
  4. unkledaddy
    unkledaddy
    Can you 'feel it' by hand?
    If so then adjust it so the throttle will do the same.
  5. I first set it up by hand pulling the cable with my wife in the car with throttle wide open. Since then I've used pliers to pull on the cable and reset the hold down screw....works like a dream now! Thanks everyone
  6. perrytudor32
    perrytudor32
    from uk
    seb,i knew you hadn't pulled it out far enough when we spoke.phil.
  7. olscrounger
    olscrounger
    glad it works--done this many times too
