Hot Rods Tetanus Tornado, 56 Chevy 13 sec for $1300 build!
Discussion in 'The Hokey Ass Message Board' started by scoggman, Jan 1, 2016.
  1. treb11
    treb11
    If this is a drag only car, don't install the sway bar, it will limit front end rise/weight transfer.
  2. Binger
    Binger
    from wyoming
    This is cool. Subscribed.
  3. Amazing that Chevy didn't put any crossmembers in the tri 5 frames!
  4. scoggman
    scoggman
    went over to my buddy Chris the outlaw Carter driver of the Conie 5 mammoth orange, late model dirt car. and with the help of his dad and Steve the local legend frame guy, it took a little bit of the tornado out of the tetanus tornado.
  5. scoggman
    scoggman
  6. I liked the mouth breathing gray beard. setting on milk crates drinking a beer. How much does that job pay? That a job I would be good at!
  7. mjlangley
    mjlangley
    from SE MI
    Great idea, sounds like a lot of fun even if it blows up on the starting line!
  8. Nostrebor
    Nostrebor
    I assume it's a high ranking job, as he got *two* crates! I never climbed the ladder higher than a one-crate rank.
    Enjoying following along as you attempt to do something with a tri-5 without spending money. It's like pushing rope, so don't give up!;)
  9. scoggman
    scoggman
    Thanks for the tip, we'll remember that!
  10. scoggman
    scoggman
    Yeah, it is pretty funny. I just finished up a model a, and the frame 55 frame is beefy compared to that, but still pretty flimsy compared to some more modern stuff. We are going to try and fab up some type of x-member I think.... If we can find some cheap box / plate,
  11. scoggman
    scoggman
    Hey, that guy moved at least two jack stands!!!!
  12. scoggman
    scoggman
    It's been fun so far!!!
  13. scoggman
    scoggman
    That is funny! Sounds about like the week I had at work last week!!!!
  14. scoggman
    scoggman
    Financial update-
    $traighten frame-
    -$14 - 12 pack bud light
    -$12 harbor freight level that fell off and broke
    Total build = $337
    patmanta, loudbang and hipster like this.
  15. If it only cost 12 bucks to get rid of the Horrible Freight level, you're ahead of the game.
  16. scoggman
    scoggman
    So..... BRAKES!!!! You guys recommend rebuilding the old drums on all four corners, or upgrading to a budget front disk brake set up?
    Or does anyone have a used set up they would like to get rid of?
    Thanks,
    Jon
  17. drum brakes are faster. You loosen them so there isn't any drag. with disk brakes their is always drag. Many Many very fast 55,s have been raced no problem with the stock brakes.
  18. Cool project.
    Is there any way you could salvage the floor and firewall from the tornado destroyed 55?
  19. YJ4000
    YJ4000
    I was going to say drums also. Keep them adjusted down just enough to not rub when you spin the wheel.
    Ryan.
  20. belair
    belair
  21. slowmotion
    slowmotion
    Right on about the brakes. A friend's track car runs way deep into the 11's (ever so close to 10's & no power adders) 3K lbs, drum brakes.
    Likin' this thread a lot.:D
  22. indyjps
    indyjps
    Drums will be fine at 13 sec, I ran well set up drums on a low 12 sec car. You get 1 good stop out of them then they cool down between runs, fade is the biggest concern with drums and it just isn't a factor when doing a dragstrip pass then cool down.
    Use the drums to fit your budget, If you go faster later on upgrade then.
    If someone has info on a disc swap from junkyard parts, chime in.
  23. treb11
    treb11
    I kinda agree with the principle that drum brakes, backed off, are low drag. But I'll be contrarian and say that late "metric" type disc calipers have "fast retract" features for low drag. If you have no front brake parts at all, don't scrimp on safety and pop for discs. And a dual master cylinder, although your local track/sanctioning body may already require that.
  24. Smoothy, loudbang and AHotRod like this.
  25. blue 49
    blue 49
    from Iowa
    I recall that in the seventies, Car Craft or some other mag, was saying that some of the faster bracket cars of the day used front drums from 6 cylinder cars, typically 9" instead of 10", to save weight. This was before light weight disc set ups were popular and affordable.
    Gary
  26. malibumonte78
    malibumonte78
    The problem with the metric low drag calipers is that they require a stepped bore master cylinder that the first bore makes up the distance that the caliper pulled away from the rotor and the second bore applies the clamping force. It is difficult to find these style master cylinders.
  27. scoggman
    scoggman
    Anybody have a stock brake pedal assembly they would like to donate to the cause / cheap. We will pay for shipping. Thanks! Jon
  28. paul55
    paul55
    from michigan
    Think I may have one! I'll see if I can find it this afternoon.
  29. Budget36
    Budget36
    That's way to much for a 12pack of Budlight... ;)
  30. scoggman
    scoggman
    Hey Paul I would appreciate it. Let me know! Thanks, Jon
