Technical Testing a Runtz voltage reducer
Discussion in 'The Hokey Ass Message Board' started by qzjrd5, Oct 1, 2017.
  1. qzjrd5
    qzjrd5
    from Troy, MI
    I had mine hooked up incorrectly and now I think in may have fried it. Does any one know how to test one with a meter?
    Thanks
    Mike
  2. greybeard360
    greybeard360
    Check resistance thru it, connect it to your battery and see if there is voltage on the output side and how much. That is two ways to check it.
    Sent from my Moto G Play using The H.A.M.B. mobile app
    Donuts & Peelouts likes this.
  3. squirrel
    connect the volt meter negative lead to ground, connect the positive lead to the regulator output, and measure the voltage.
    (I'm assuming it's an electronic regulator, not a resistor. Pictures would help us help you, as usual)
  4. qzjrd5
    qzjrd5
    from Troy, MI
    It looks similar to this. Thanks!
  5. squirrel
    That is an electronic regulator. Connect it to power and ground, and see if you get 6v out of it
    What did you connect it to? if you put too large of a load on it (or short the output to ground), it will fry.
  6. d2_willys
    d2_willys
    from Kansas
    Test it first. If no output, then take the blue heat shrink off and replace regulator with one from Digikey. Much cheaper that way. BTW: These are only good for one gauge. You will need more to run other gauges.
