Technical Temperature gauge size issue
Discussion in 'Traditional Hot Rods' started by Joliet Jake, Jul 18, 2019.
  1. Joliet Jake
    Joliet Jake
    from Jax, FL
    For my 31 Roadster project I will be keeping the original gauge panel. These cars originally came with a 1-1/2" amp meter on the right side that I want to replace with a temperature gauge. Normally, Google is my friend but not in this case. I cannot find a temperature gauge smaller than 2" even in the UK, I have a 2" gauge but it's too large and looks way out of place. Anyone have any experience with smaller gauges or have any ideas? Here is a pic of your typical A dash panel, not mine just a web pic but it is the same view I have. Mine has the same speedo, fuel level and switch.
  2. squirrel
  3. be cautious here. I see you are using the stock A gas tank. I used Stewart Warner mechanical gauges in the left and right holes. The stem off the back of the gauge would hit the tank. I ended up trimming the sleeve on the back of the gauge and bending the capillary tubes to get them to work.
    INVISIBLEKID likes this.
  4. I hate it when size is an issue...sorry, someone had to...
  5. Joliet Jake
    Joliet Jake
    from Jax, FL
    Thanks Jim,
    yea I have seen the "new" look/style gauges but the look is all wrong. I have considered taking one apart to change the face to a more "vintage" look.
  6. Joliet Jake
    Joliet Jake
    from Jax, FL
    I retained the tank, but not using it for fuel, I will modify it for the deeper gauge. If I find the right gauge I will make it work.
  7. Bandit Billy
    Bandit Billy
    You could buy the gauge Squirrel posted and take it apart, re-size and print a SW face off line that you like onto decal paper and stick it on there, reassemble and install. Sometimes off the rack just don't cut it.
  8. Maybe get a under the steering temp gauge for an A.
  9. winduptoy
    winduptoy
  10. Mechanical will cause some issues with the fitment.... Electrical will be a lil more forgiving on the back side of the gauge...... 2 1/16 will jive nicely. You'de just have to open things up a lil bit......
    Not too difficult, and doesn't look out of place.
  11. 57tailgater
    57tailgater
    from Georgia
  12. Have you thought of using one of those Harley oil tank mechanical dipstick with gauge. They are about $20 you would have to bring it to a gauge shop and get a capillary tube put on it.
  13. I'd use a vintage SW 2" gauge and put a curved glass from a pocket watch in it.
  14. X-cpe
    X-cpe
    British/European cars?
  15. Joliet Jake
    Joliet Jake
    from Jax, FL
    I did look into those, Smith has really nice gauges, they offer small oil gauges but no water gauges.
  16. denis4x4
    denis4x4
    from Colorado
    I'm using a MotoMeter on both of my A's.
