Technical Tell me my next move! AV8 steering
Discussion in 'Traditional Hot Rods' started by Pete Poling, Dec 10, 2019.
  1. Pete Poling
    Pete Poling
    F1 column is rebuilt and installed so next is to figure out my drag link. I plan on using a speedway tube with the 7 degree tie rods on each side. I’m trying to figure out the easiest way to connect the pitman arm to the hoop style arm on my spindle. As you can see in my pics the pitman arm hits the split bone on the driver side, I think my next move is to flip my split wishbone brackets to move the tierod to the inside, moving my bones in. Thoughts? I’m still not sure it will buy me enough room to clear while turning. Can I cut the pitman arm down so it sits just above the wishbone? Can I heat and bend it out once the bone brackets are flipped? Do I need to heat and bend the steering hoop on the spindle? Trying not to overthink this.
    Thanks[​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG]
  2. alchemy
    alchemy
    How about mounting the wishbone brackets to the inside surface of the frame? Will gain you two inches. You could still leave the rod end facing the outside, cause I think they look better like that. Then heat and bend the pitman arm outward a bit to finish getting whatever clearance you need. Do the bends close to the ends to keep as much length as possible.
    Looks like you might want to screw the rod end in at least a half inch more when you are doing the bracket moving. They should have most of the threads inside the bung, not hanging out in the air.
    Do not cut the pitman drastically shorter, that will really screw with your steering geometry.
    alanp561 and Pete Poling like this.
  3. Tim
    Tim
    from Raytown Mo
    I’d heat up the pitman arm and put a jog in it to move it towards the frame a enough to clear the nut on the back side between the pitman arm and the wishbone. Trying to keep the length as close to how it is now as to not effect the ratios to much.
    From the looks of it moving the wishbones in board would still cause interference just in a spot further over. Though I do generally advocate for keeping the wishbones as triangle shape as feasible I just don’t think it’s work that needs to be done right now.
    can you take a photo with a broom stick or something mocked up so we can get a better idea of where things will actually land?
  4. Tim
    Tim
    from Raytown Mo
    To @alchemy ’s point I guess you could just take the rod ends lose from the bracket and push the wishbones in and bolt them into the back side to see how much it really moves them. They won’t seat because of the taper not being there but it would be easy to do and give you an idea of how much room it would or wouldn’t give you
  5. Pete Poling
    Pete Poling
    Yea I need to move the brackets 1/2” towards the front to get more thread in the bung and I thought I could flip them at the same time. The frame isn’t boxed... how would you get enough weld on the bracket?
  6. Tim
    Tim
    from Raytown Mo
    Could still weld them to the outside of the rail and just flip them so the tappered bung faces in not out
    Pete Poling likes this.
  7. Pete1
    Pete1
    from Wa.
    Consider a 37 to 48 steering box. The pitman arm will be up instead of down and then out of the way. The drag link will then be parallel to the radius rod also, which is desirable.
  8. Pete Poling
    Pete Poling
    [​IMG][​IMG][​IMG]
    It’s closer with the bone on the back side but I think I’ll still have to bend the end of the pitman arm out away from the bone
    osage orange and Tim like this.
  9. Tim
    Tim
    from Raytown Mo
    Cool, not nearly as much of bend needed
  10. flatford39
    flatford39
    I had to bend my pitman arm as well. It made it about a quarter inch shorter that I don't think it is a big deal. Heat...do the first bend..let cool..do not squelch, heat again...do the second bend and let cool naturally again.
  11. Pete Poling
    Pete Poling
    So you have to bend both sides? Heat under where the sector shaft goes in and bend out, let cool then heat and bend just above where the tierod goes in back in so the two holes are parallel?
    Inked Monkey and Tim like this.
  12. alchemy
    alchemy
    If you wanted to move the wishbone bracket to the inside of the frame you could box the area about a foot long. I'd also probably recommend a gusset from the hangdown to the under side of the frame. My little bro had a car with similar brackets, and one bent on a hard pothole hit. He replaced with thicker stuff, and a gusset.
    Yes, the eyes of your pitman arm need to be parallel to each other.
  13. Pete Poling
    Pete Poling
    I don’t think it’s gonna go on the inside, that’s a busy area with the clutch linkage and all. So, so far I’m gonna flip the brackets so the tierod comes in from the back side then heat and bend the pitman arm out away from the bone. Thoughts on heating and bending that steering hoop down? It seems like you see them just like I have it or bent down so the tierod comes up from the bottom. Some guys say you need to do it some say it’s fine from everything I’ve read on here[​IMG]
  14. Tim
    Tim
    from Raytown Mo
    I think your trying to get the dragnlink about parallel with the wishbone. Dropping the hoop to do that isn’t uncommon
  15. irishsteve
    irishsteve
    I have a pitman arm with 21A-3590-8 on it.It bends inward toward the engine right below the spline a good 2 inches.Can you taper the underside of the spindle steering loop,and run the steering rod from the bottom down to the inside of this pitman? One of those speedway dropped tie rod ends might help on either end if you need more offset.
  16. rpu28
    rpu28
    from Austin
    On my AV8 roadster pickup I used the box out of the '40 Ford that donated my front axle, wishbones, spring, etc. You'll need a U-joint in the steering column, but the box fits fine inside the frame rails. Better geometry and less clutter, too.
  17. Inked Monkey
    Inked Monkey
    I just went through this on mine. In the link below. Just heat it up and bend like you described above. Out right below the sector shaft and then back in right above the tapered end.
  18. 55styleliner
    55styleliner
    Make sure you double check your ratio between the pitman arm and the steering arm. I had to shorten my pitman arm quite a bit as that hoop style steering arm is pretty short. I have the same setup. I did have to bend the pitman arm as well.
    18581576-2F72-4F11-B310-07CC928DDED2.jpeg 28D8D0EE-F5D0-4452-B168-58171CABCA0A.jpeg
    Tim and Pete Poling like this.
  19. Pete Poling
    Pete Poling
    I’m sorry but I spent way to much money and time finding, rebuilding, welding on the f1 box to change it now. But thanks for the ideas guys!
    -Brent- likes this.
  20. Aaron D.
    Aaron D.
    If it were me, I'd flip the wishbone mounts and mount the wishbones on the inside. Heat and bend the pitman arm, it will shorten it a little, but it looks like it should come up a little anyway. Heat and bend the hoop to lower it a little, mount your drag link to the bottom of the hoop. With the pitman shorter and the hoop lower, it should bring the drag link more parallel with the wishbone.
    Pete Poling and osage orange like this.
  21. Pete Poling
    Pete Poling
    I did think about leaving the brackets the way they are and bending the pitman arm in, I’m just not sure about clearance through the full range of travel.
  22. flatford39
    flatford39
    I also bent the steering hoop at the backing plate down. Let me see if I can find a pic of my pitman arm. It actually wasn't that hard...you just need a lot of heat and a big pipe wrench. 20190929_135735.jpg
    -Brent- and Pete Poling like this.
  23. Tim
    Tim
    from Raytown Mo
  24. tom brown
    tom brown
    consider cowl steering -able to keep straight angles no bends- check out sprint car steering- no play and looks cool
  25. sawbuck
    sawbuck
    from 06492 ct
    oh no he said cowl steering !
    Texas Webb likes this.
  26. rusty valley
    rusty valley
    you need to be as close to the frame as possible also so when the wheels are cranked hard left the tire does not hit the drag link
    irishsteve likes this.
  27. Model A Gomez
    Model A Gomez
    Running about the same setup and bought the reamer to flip my wishbones and bent the pitman arm, barely clears at full right turn. I bought a 37-40 pitman arm since it is longer than the F1 arm and filed the indexing bars out with a triangle file so I could index it where I wanted it. Pictures don't show it real well but are all I have on the computer.
  28. Phil P
    Phil P
    My pitman arm is on the inside and I won't have to bend it, but my pitman arm shaft doesn't stick out as much as your's. In this picture Nothing has been tightened. You can't see it from this angle one's everything is tight I'll have about an inch of clearance between the tie rod nut and the bone.
  29. Pete Poling
    Pete Poling
    The more I think about it, it just seems like it may be easier to bend the arm in towards the frame, use the reamer and run it from the inside out on the pitman arm. With the brackets flipped where the tie rod comes in from the back side, that’s seems like it putting things in a bind and it would be harder to square up the front end to the frame. I gotta go out there and stare at it before I move forward.
  30. Tim
    Tim
    from Raytown Mo
    You’re over thinking it on the bind man. I’ve got mine split and mounted 4 inches away from each other under the car. The front cross member and spring is getting things square for the most part. The bones just keep it from moving out of square - over simplifying it here but it’s all that matters for this moment
    -Brent- likes this.
