Hot Rods technical gas gauge traditonal hot rod
Discussion in 'The Hokey Ass Message Board' started by studebaker46, Oct 12, 2015.
  1. studebaker46
    studebaker46
    can any one tell me the proper way to test a gas gauge it shows full all the time two different sender 2nd one known good thanks in advance Tom
  2. 54fierro
    54fierro
    from san diego
    Disconnect the wire to the sender directly from the guage. That should peg the guage on way or the other. Next jump a wire to ground from the post on the guage(sending unit side). It should peg to the opposite side.
    If it works as it should and you know the sender is good there is likely a problem with the long wire to the sender. Good luck
