**TECH WEEK** Install soft top on Model A sedan and custom rain gutters
Discussion in 'The Hokey Ass Message Board' started by Crusty Nut, Jan 11, 2010.
  1. Crusty Nut
    Crusty Nut
    My usual disclaimer is if I can do this, then so can you. It is true here too. In my opinion a vinyl top looks the best (most traditional:confused:) on a Tudor. This is the blow by blow of how I did mine last week. I followed my own recipe of parts I thought would work better than chicken wire and cotton, and it seems I was right.
    I also did not want to use stock type rain gutters, so I built some.
    First gather your materials. You will need to order the roof vinyl and the steel moldings from your favorite Model A parts house.
    The aluminum gutter extrusions I ordered from Restoration Supply.
    Everything else you need is easy local stuff.
    I started by filling the roof with a piece of 1/8" Masonite. I wasn't sure how it would work on the compound curve, but I put one relief cut on each side and it laid down perfectly. I put the relief right over the forward most roof bow to hide it since the roof bows and stained masonite will be the finished inside roof. I held it all down with a handful of small screws. I put this on about a month ago, so I brushed some black paint on the rough side to make it look a little better.
    Next you will need some glue and 7 feet of 1/4" Landau foam (unless you want to use cotton batting)
    ********Please let me post it all before you comment. I'll have 4 or 5 posts.
  2. Crusty Nut
    Crusty Nut
    Mark the middle of the foam with a sharpie.
    I also put masking tape all around the edges on the car. I marked the middle of the car on that.
    So I sprayed some glue down the middle of the car and foam and let it tack up. Then glued down the middle 2 feet of the roof so it would stay put.
    That let me smooth out the foam and mark the edges for trimming.
    All trimmed
    In this picture you can see I marked the middle of every nail hole to make it easier to find where the nails should go when the big piece of vinyl is draped over it. This was a huge help.
    mgtstumpy likes this.
  3. Crusty Nut
    Crusty Nut
    Next comes the vinyl. I had built a simple frame out of 2X2 wood and stapled the vinyl to it a few days earlier. This helped a bunch to smooth out the creases from shipping and may have even pre-stretched it some.
    You will need help with the stretching and nailing. My lovely wife was a great helper. I used stainless body nails from Sac Vintage Ford. I bought a big bag years ago and it seems to be a lifetime supply.:rolleyes:
    Start with centering it on the car and run 10 or so nails into the header wood.
    *IMPORTANT* Don't sink them all the way it. Leave the heads about 1/4" up so you can easily pull them if need be.
    Then go to the back of the car and pull it tight, but not so tight you rip out the nails in the front, and put in another 10 or so nails. Remember, none of the nails get set all the way down until all the nails are in all the way around the car.
    At this point, working in the front, or back, pull and nail until you are about 8 inches from the corners. Do the same to the other end.
    Then, start on the sides with another 10 or so in the middle of the side.
    Do the same on the other side. Pull and nail, pull and nail, pull and nail.
    By now it is shaping up and you are getting stoked.
    Leave the 4 corners for last, pulling in a diagonal toward the corners of the car. You guessed it, more pulling and nailing.
  4. Crusty Nut
    Crusty Nut
    Go ahead and trim off the excess on the sides, you know you want to.
    I chose to use the 2 piece stock type steel trim front and rear. I know why most people use hide-em welting, the steel is a pain in the ass! The front was pretty easy, but the rear has a long compound curve. Just go slow and don't let it think it is in control, you are. You may need to call it a few names.
    You will want to put some sealant under the steel. I used 3M strip caulk rolled out real thin. I'm sure others would work fine too.
    Nail the lower half of the trim to the car. To avoid the nails from the vinyl, remember the lines on the masking tape showing the nail holes? I went back and made a dot wherever the nails ended up, so I knew where they were too.
    Once it is on, gently snap the top piece into the lower piece. I recommend talking nicely to this piece, or your project could go a little sideways.
  5. Crusty Nut
    Crusty Nut
    Next is rain gutters. I didn't want to use stock type gutters and the reviews of the 2 piece aluminum ones were varied.
    I bought a stick of the gutter extrusion from Restoration Supply. It just comes straight.
    Using my torch to anneal it, it became very soft. I then put my shrinker/stretcher to work matching the curve of the body. I am new to the shrinker/stretcher, but it was quite easy and satisfying. I cleaned them up some, but was too lazy to polish them. I was beat from all the pulling and nailing.:rolleyes:
    So, I just drilled them at even intervals and used stainless screws to attach to the body.
    I used some black 1-shot and a brush and painted the front/rear trim black and bingo bango, the roof is done. I did this over the couse of a few hours for a few days. It isn't really difficult work, just a lot of it.
    Viva la Tech Week!
    Kiwi 4d, BradinNC, GASSERBOB and 3 others like this.
  6. hvychvy
    hvychvy
    Looks great,thats exactly what she neded!!
  7. ccain
    ccain
    That looks awesome! Nicely done!
  8. 31modelo
    31modelo
    Looks great and thanks for the tips.
  9. BuiltFerComfort
    BuiltFerComfort
    This is good stuff! Good step-by-step and also confidence-inspiring.
    Are you going to relieve the front corner of the rain gutter? Seems like the rain gutter sticks out a bit and might catch on something (like your hand?) But it could just be an artifact of the picture angle.
    It also looks like rain would drop inside the raised part of the body at the rear - the gutter would dump rain on the door side of the bump. Again might be picture angle?
    In looking at it I'd either pinch the front closed or angle grind it, and try to find something to fill in the gutter at the back, so if you had to open the back door in the rain it would not drip on you.
  10. That's great looking! Do you use the same techniques to do a Coupe top? I'm gonna do mine soon.
  11. Rusty
    Rusty
    thats awesome!!! thanks for sharing
  12. Crusty Nut
    Crusty Nut
    The front end is just fine. I think it is the camera angle. I the car is a tudor, so no worries with water coming of the rear gutter. Also, with the way the gutter rakes down to the front, 95% of the water comes off the front anyway. I water tested it and the water flows rear nice.
    Same techniques, just a little different. Coupes roof vinyl doesn't go all the way down to the gutters.
  13. irace2win41
    irace2win41
    Nice step by step for us Tudor guys. Made it look easy....
  14. 1950ChevySuburban
    1950ChevySuburban
    from Tucson AZ
    Very nice! Now you've got me re-thinking using my wagon roof I got for my Sedan.
  15. Von Rigg Fink
    Von Rigg Fink
    from Garage
    Thank you for this..
    I have looked at the way "ford" did this originally, http://abarnyard.com/workshop/roofinstall-1.htm
    and its very close you your way, with the exception of some of the modern use of todays materials.
    the only thing i dont care for are the screws showing on the after market gutter, i have nice OEM's so i will go that route, but everything else you bring to the table is greatfully appreciated
    Looks great
  16. josh77
    josh77
    Excellent job, thanks for the pointers. Will be very useful when I do mine. Where did you get the 2 piece steel trim? I like that look a lot more than hide em.
  17. Crusty Nut
    Crusty Nut
    All the ealy Ford parts suppliers have it.
  18. chaddilac
    chaddilac
    Looks great... I just think the gutters should be black also...:D
  19. Crusty Nut
    Crusty Nut
    yep, I've been thinking the same thing.
  20. Very nice, thanks for showing me the way.
  21. Crusty Nut
    Crusty Nut
    thanks all!
    Bump for tech week.
  22. Hot Turkey
    Hot Turkey
    Very well done.
  23. falconsprint63
    falconsprint63
    from Mayberry
  24. draginsteel
    draginsteel
    Thats a great concept.
    That aluminum extrusion is also available at awning shops.
    We would pop rivit it to the metal awning frame and then sew a 1/4" pvc tube into the awning cover. It would then slide into that extrusion and the fabric pulled tight. I don't see why it wouldn't polish nicely.
  25. Slim Pickens
    Slim Pickens
    Thanks, great tech tip. Slim
  26. zman
    zman
    from Garner, NC
    all tech week to the top 7
  27. Vergil
    Vergil
    Great job, as well as a very nice car, thanks for sharing.
    Vergil
  28. Craig Owens
    Craig Owens
    Great looking job, Matt! Your car really turned out nice...can't wait to see it in person.
    Craig
  29. bartmcneill
    bartmcneill
    from Ada, OK
  30. Crusty Nut
    Crusty Nut
    Looks like it worked for you. Happy I could help.
