I started looking to see how I was going to run taillights for my A project. There where so many options, 50 Pontiac, 38-48 Ford, Early Chevy, Etc, Etc. <O</O I decided not to molest the rear sheetmetal panel by installing flush/frenched mounted lamps. <O</O Here is my take with 33-36 Ford Lights installed on the rear sub-frame channel. Went to the local Steel place and picked up a foot of 12ga, 4" OD pipe. 3 bucks and change + 7 bucks cutting fee (sheesh). Cut off about 4" length: Cut it in half: Cleaned it up with a Die Grinder: (Smokes here so you can visualize size) Figured out where I wanted to place them: Cut out the metal: Made template for mounting flange: Cut Out mounting Flange: Welded Flange to Pipe: Welds Cleaned up: Test Fit: Sprayed on a little weld thru primer: Tack welded and test fit: Finished Product: (Needs a tad more touch up grinding) Thanks for looking and Hope you like em. Dave L. <O
WAUW! That's it! One more option on what to light your rear up with! Have been wondering, what to hang on my A's ass (A's ass - he!), and this is a really good alternativ to so many other solutions... Kuul idea! Keep 'em kruzin! Dannerr
