TECH -- How to make a Model A RPU Quarter Panel
Discussion in 'The Hokey Ass Message Board' started by justheman, Jul 7, 2009.
  1. justheman
    justheman
    For my Tech write up I decided to show how I have been trying to make a model a quarter panel. This is my first tech write up so don’t go to hard on me. I didn’t finish it but you get the idea. So I started with standard piece of Sheet metal. The first thing I had to do was measure 5 and ¼ inches down, this is where I would roll the bead, the bead is put there as the bottom of the belt line. Using my Poor quality Beadroller it takes quite a while to do as I dont have a sweet power roller like the Baileigh one ;)
    [​IMG]<br>[​IMG]<br>[​IMG]
    Next I cut out the panel about 30 inches total so that I have some room to spare. I measure 21 inches from the bottom of the belt line and put a break in the panel.
    [​IMG]<br>[​IMG]<br>[​IMG]<br>[​IMG]
    Using my jig that I made for the bottom roll I flip the panel upside down and tighten the Jig down so that I can create the bottom roll. I roll it up by hand moving a few inches at a time. I then measure and put a break in the roll to match the factory qt panel.
  2. justheman
    justheman
    Once I have created the bottom of the qt panel finished I move up to the top and finish my two other bends the first being 2 and 1/2 inches from the belt line and the second being 1 and 1/4 inches from the last bend
    Now I have the overall look of the qt panel. Next I cut out two pieces of sheet metal that I traced to have the same contours as the panel. [​IMG]<br>[​IMG]<br>[​IMG]
    I then use my Poor quality Shrinker/Stretcher (Sure could use a Baileigh Shrinker Stretcher that would help out quite a bit) To make the contour match the old qt panel. I do that twice the second side I do it with a piece that I put in two breaks so that can flush fit my doors but without the breaks I would have a stock qt panel. I then Tack the ends in place. Where I will later finish welding and cut and trim any left over areas. [​IMG]<br>[​IMG]<br>[​IMG]<br>[​IMG]<br>[​IMG]
    My quarter panel has been extended to 15 inches so to make up for the extended cab that my grandfather wanted. Here is the finished product and it next to a reproduction qt that i put an extension on.
    [​IMG]<br>[​IMG]
    Now I just need to repeat the step one more time for the other quarter and then make two new door skins. which if anyone wants to see I will write up a tech article when I do.
    Please let me know if you have any questions comments or want any other photos or measure ments.
  3. dirtbag13
    dirtbag13
  4. matt 3083
    matt 3083
    from Tucson, Az
    Really nice. I love it when a non pro does something
    like this. It says that if I try I can too. Thanks.
    Matt
  5. cretin
    cretin
    Looks good. This is the stuff I like to see in tech week, home garage ingenuity.
  6. Kiwifruit
    Kiwifruit
    Great Tech!
    Yes,
    please post another article on the doorskins.
  7. Crankhole
    Crankhole
    Awesome! Where do I send payment?
  8. Xdrag48
    Xdrag48
    Good stuff there! Please post the making of your doorskins also...
    Steve
  9. justheman
    justheman
    I will definetly do that when I get around to making them, my hope is that I win the contest :rolleyes: (high hopes) so I can show the difference between the tools I was using and a baileigh tool.
  10. the-rodster
    the-rodster
  11. Very excellent....Carl Hagan
  12. chop&drop
    chop&drop
    Great tech. Shows that a lot can be done with a little. A little skill, a little patience, a little encouragement and a little bit of equipment.
  13. justheman
    justheman
    I have looked at that thread so many times I will definetly be looking at it alot more when i go to make my doors and door skins as I have to make everything 2 inches longer.
  14. Gahrajmahal
    Gahrajmahal
    Just curious, how much time is in the panel? How much in the fixtures?
  15. punkabilly1306
    punkabilly1306
    from ohio
    you did a good job but i think you need to mention the tech sponsors name a few more times lol
  16. justheman
    justheman
    I spent about 2-3 hours on the qt panel and that included making the jig... but that was my 5th attempt or so at making them to finally get it the way i liked it....
  17. BigRed390
    BigRed390
    Nice work! I'm stealing your ideas for home-made tools. Love the ingenuity!
  18. dana barlow
    dana barlow
    from Miami Fla.
    1. Y-blocks
    very nice,would love to see door job as well,thanks for showing.:D
  19. Saturday night zombie thread
  20. Roupe
    Roupe
    Nice work! What gage steel are you using?
  21. shtterbug8
    shtterbug8
    nice job. would actually like to see a video of the metal being bent in the jig. im having a hard time wrapping my head around your jig. not fully understanding how its working. thanks chris
