TECH: How to fix any automotive flared fitting leak for 20 cents
Discussion in 'The Hokey Ass Message Board' started by Prop Strike, Aug 28, 2006.
  1. Prop Strike
    Prop Strike
    Works on brake, fuel, power steering,oil, trans, vacuum or any
    other closed system using a flared fitting. Any flare angle.
    Sorry for the quality of the pics in advance.
    I will use this on every flared connection in the future.
    Use hardware store (got mine at Ace) trim or finishing washers
    made of brass or aluminum. Like the kind common in cars
    (usually chrome) on interior trim. For 3/16 size line fittings I
    had to trim off the very outer edge with a pair of scissors.
    Put them at your connection inserted upside down. You might
    cram them down in with a small deep socket. Seat the trim washer
    against the flare, tighten up the line, and no leaks. Cures leakage
    caused by nicks and scratches, burrs, etc common to these
    connections. When the connection is tightened the brass or
    aluminum deforms perfectly to make a conical washer and seal
    any imperfections. If the b-nut on the line doesn't seat fully, use
    more than one as a shim to fill the void. Works best to form them
    one at a time.
    Hope this helps.
    Bomb and dennis g like this.
  2. Cruiser
    Cruiser
    Prop Strike,
    :D Great idea, will fill it away for that rainy day when I need the fix.
    Thanks
    Cruiser 49:cool:
  3. Squablow
    Squablow
    I'm not following on how this works
  4. grego31
    grego31
    from Sac, CA
    Nice tech tip, will help with some of those old brake lines that are crusty at the ends. If I get off my lazy ass and away from the computer, I can stop that leak on the t-bird.
  5. Prop Strike
    Prop Strike
    The trim washer goes between the two fittings. The soft brass or aluminum takes the shape of the flare when you tighten the connection. Hope that helps.
  6. Brad54
    Brad54
    from Atl Ga
    Every time I've ever had a fitting leak, I simply back it off/snug it up, and repeat a few times.
    The fittings are brass already, so the flared steel tubing end will seat into it. If you're lines are crusty enough that you can't get a seal, maybe it's time to replace the lines?
    -Brad
  7. T McG
    T McG
    from Phoenix
    I must be getting old, I had to use a magnifying glass to read that little print. In 30 plus years of car building, I've never had as many leaks as you have trim washers. I think it would be easier to get a good flaring tool and fix it right. Good tip in a pinch though.
    WDobos likes this.
  8. UnIOnViLLEHauNT
    UnIOnViLLEHauNT
    Haha...thats cool.
  9. Roothawg
    Roothawg
    It's like a conical (sp) washer. Brand new parts leak sometime. Conical seals are used on AN aircraft fittings at times.
    Oh and here it is in bigger font.
    one at a time.
    Hope this helps.
    fauj and 59Apachegail like this.
  10. Prop Strike
    Prop Strike
    Thanks for the assist root, the typing looked normal to me but my computer hammer is broke. One leaker is all it takes to find a fix.
  11. Thanks for the great idea, it is absolutely brilliant.
    I spent an hour searching for conical washers ...they are very hard to find
    as salesmen usually don't remember that they sell them unless you give them a part number.
    Now I will use trim washers instead. Great idea.
  12. Roothawg
    Roothawg
    Sadly, PropStrike passed away. He was my hot rod buddy for years. Still miss him. Glad to see this come up again.
  13. BJR
    BJR
    I don't see the need. I bet one in a hundred flares I make leak, and it is usually a piece of dirt in the flare that when removed fixes it. I say get a new flare tool and do it right. Why fuck around with brake lines. If you crash you may kill me in the process. Do it once, do it right.
    weeniewawa, INVISIBLEKID and egads like this.
  14. BJR
    BJR
    This came up while I was typing, doesn't change what I typed, just want to give my condolences to his family and friends.
  15. Roothawg
    Roothawg
    We had fought this particular flare for weeks. Done all of the above, tried it all. This was in desperation and it worked.
    Thanks for the condolences.
  16. fiftyv8
    fiftyv8
    from CO & WA
    "The fittings are brass already, so the flared steel tubing end will seat into it."
    Something don't sound right about that comment above???
  17. They have them for hydraulics also, called a flair gasket.
    fauj, Okie Pete and Johnny Gee like this.
  18. Fabber McGee
    Fabber McGee
    Some fittings are brass. I don't recall ever seeing a brass wheel cylinder or brass ends on a brake hose other than the block that mounts to a differential.
  19. Roger O'Dell
    Roger O'Dell
    Haven’t used them in years at TWA used them on hyd Sys , they were referred to as conical seals
  20. how do you guys dig up this old thread?
  21. cool idea, I'll throw a couple in my road box. Just in case. :)
  22. ring gap
    ring gap
    Also lets say you want to close off a brake line ...dig through your nail box to find the right size head ...cut head off nail put head in fitting tighten ...;)
  23. vtx1800
    vtx1800
    I worked aerospace in the late 60's after I got out of the Army. Everything had stainless steel tubing/piping and we used a soft conical seal of some type on those fittings. I would have never thought about using something like that on brake tubing.
  24. Johnny Gee
    Johnny Gee
    from Downey, Ca
    I'll stick with these as well. A potato isn't a tomato.
  25. Interesting info.
  26. Bandit Billy
    Bandit Billy
    Cool trick, I look forward to using this one.
    Roothawg and Speedys Garage like this.
  27. dodge35
    dodge35
    from kentucky
    Grainger sells them, they are copper.
    Roothawg likes this.
  28. Fabber McGee
    Fabber McGee
    I worked road construction for many years fixing the big earth movers. Most of the time there were no small soft copper gaskets on the field truck. There were, however, always wire terminals. Cut the ring off a wire terminal and presto... you have a small copper gasket for a banjo fitting, also would work well for a flare gasket.
    I didn't think of it myself, one old guy I was on a job with didn't bother cutting the tail off the terminal. Pretty obvious what he was using. It also made a nice handle for installation.
    F&J, Roothawg, lothiandon1940 and 3 others like this.
  29. AD8
    AD8
    from Chicago
    Sorry to hear Prop Strike is gone. Was posting to thank him. After reading post, I bought a small assortment of copper conical washers. Though I’d give it a try on a bothersome leak at the fuel inlet on a recently rebuilt Rochester 2 bbl. Even with a new flare; line still leaked. Snuggled up the first attempt and fired up the ol’ 55... Dry as a bone. Thanks Prop, wherever you are. Rest In Peace.
    AD8
    HunterYJ and Roothawg like this.
  30. Blue One
    Blue One
    from Alberta
