Tech: Adapt a bullet to your steering wheel
Discussion in 'The Hokey Ass Message Board' started by choppermatt, Oct 24, 2007.
  1. choppermatt
    choppermatt
    This is an easy tech, most people could probably say just silicone or glue the bullet to the wheel but I wanted to make it easily removable. BTW this is on a 53 chevy stock wheel.
    First I removed the stock center cap and horn ring.
    Sorry for the crappy edges on the adapter I was in a type of rush with bad tools. Anyway I took the center cap and made a cutout from it, then transferred that cutout onto sheet metal and came up with this adapter. After cutting the circle. I notched the edges to fit in and then drilled the wholes to mount it on the horn ring. The big center whole is to clear the steering wheel nut. I then made the "bridge" over the nut about 1/2 inch high and 1 inch wide.I drilled a hole in the center and screw a stud in from the top about 1 1/4 inch tall. The stud is just from one of those dry wall anchors. I welded from underneath and ground it smooth. This was just so I didn't get slag on the threads.
    The new adapter fit perfectly in the horn ring and i mounted it in between horn ring spacers. Just make sure the stud is centered and it is an easy way to screw on a cal-custom 2 1/2 inch bullet to your stock wheel.
      97.1 KB
      98.9 KB
      97.5 KB
      92.3 KB
      94.5 KB
      99.9 KB
      99.6 KB
  2. oldchevyseller
    oldchevyseller
    from mankato mn
    ask yourself why
    sammy davis jr lost his eye in a 53 cadillac ;)
    ,because of the bullet in the steering wheel, :rolleyes:
    and they were not as pronounced as that one
    go figure of all things to get rammed into maybe because he was short
