So I'm playing with a 1941 1.5 ton Ford, I pulled the steering wheel because it was crispy and planned to use an Ansen aluminum hub to put a different wheel on it, at least temporarily. The aluminum hub wouldn't seat down far enough to get the nut started. I tried a 30-31 Model A wheel and it fit oddly enough. I had wondered if the larger truck shaft was larger but when the Model A wheel fit on it made me wonder if the aluminum adapter was off. It doesn't look buggered though. Anyone know these things for certain? Maybe i need a deeper taper on the adapter?
I think you know the answer. If the "A" wheel fits & the adapter will not, doesn't that tell you the Ansen part is not correct.
