What are you guys running on your race cars or Super Stock looking cars? Not an application from Moroso for their trick front springs...I know back in teh day we would use 6 cyl springs in our v8s for a lesser spring rate for a bit more lift, but I want a hair more height as well for a slight nose up attitiude with A-arms. i guess you could use those 2 inch spring spacers if it didn't fark up you geometry...or if one could produce a chart with coil spring diameters and free/installed heights you could probably find you a crossover that would work....lots of muscle car (camaro) springs out there....mine is sbc car. Hans
235 powerglide wagon with a/c had a spring that was pretty hefty, Moog number 6004. Also used in 375/PG convertibles with ac
I got big block springs in my '62. Well I guess big block springs is probably the wrong word they are for a W motor. With the 283 under the hood it doesn'r change the ride height noticably from no engine tranny to loaded 328 turbo 400 combo.
Hey Porknbeaner, you got any pics? I saw the red one in project form in your album. Hows teh ride , pretty stiff or still float?
moog Spring # 6004 Inside Diameter 3.820 Bar Diameter 0.671 Install Height 11.81 Load rate (lbs) 2264 Spring Rate (Lbs/in.) 325 Free Height 18.78 End Type tangential ends
It is still in project form 3 cars back unless I take a wild hare. Looks rough but it may be the quickest to get on the road believe it or not. Anyway I'm going to say that it is going to ride pretty stiff. When the wife and I were in highschool we had one set up the same way for a couple of weeks and it was pretty firm riding.
FRONT FULL SIZE CHEVY SPRINGS MOOG NUMBERS Spring # 6084 Inside Diameter 3.820 Bar Diameter 0.671 Install Height 12.00 Load rate (lbs) 1805 Spring Rate (Lbs/in.) 377 Free Height 16.79 End Type tangential ends 58-68 full size HD 2dr sedan Spring # 6004 Inside Diameter 3.820 Bar Diameter 0.671 Install Height 11,81 Load rate (lbs) 2264 Spring Rate (Lbs/in.) 325 Free Height 18.78 End Type tangential ends 59-64 Spring # 6000 Inside Diameter 3.820 Bar Diameter 0.656 Install Height 11,81 Load rate (lbs) 2063 Spring Rate (Lbs/in.) 305 Free Height 18.58 End Type tangential ends 59-64 Spring # 661 Inside Diameter 3.680 Bar Diameter 0.609 Install Height 11.00 Load rate (lbs) 1610 Spring Rate (Lbs/in.) 275.6 Free Height 16.84 End Type tangential ends 58-64 Spring # 658A Inside Diameter 3.810 Bar Diameter 0.687 Install Height nov.81 Load rate (lbs) 2052 Spring Rate (Lbs/in.) 403.9 Free Height 16.89 End Type tangential ends 58-68 full size 4dr sedan 71-72 maverik w 6cyl REAR SPRINGS Spring # 6033 Inside Diameter 3.670 Bar Diameter 0.656 Install Height 11.00 Load rate (lbs) 2005 Spring Rate (Lbs/in.) 370 Free Height 16.44 End Type tangential ends Spring # 6041 Inside Diameter 3.650 Bar Diameter 0.718 Install Height nov.25 Load rate (lbs) 2806 Spring Rate (Lbs/in.) 499 Free Height 17.des End Type tangential ends So from these springs the 661 would be your best bet for drag racing with a spring rate of 275. This could be used with sbc or W motor as it is still a decent capacity. The 6000 is also a decent spring and would give some extra height but a hair stiffer....
