I'm building a 1926 tall t sedan with finders on a spirit industry's model a frame. It has the 32 style front crossmember. I trying to figure out what radiator to use. I tryed a 28-29 Walker radiator but it was tall. A regular T radiator won't work on the front crossmember. I was thinking a lo-boy radiator. Didn't know if that would still fit in the T shell. I'd like to have a/c too. Don't know about fitting the condenser. What have you all seen or used on a sedan or coupe?
Two companies that have custom made radiators for me are The Brassworks ($1000.00) and PRC (aluminum but only $ 500.00) Both did a good job and put whatever tanks I needed to fit my frame and shell. You will get other suggestions, but those are just two I personally like. Don
