Projects Taillight swap
Discussion in 'Traditional Customs' started by Cortney, Aug 10, 2015.
  1. Cortney
    Cortney
    So, it's not easy finding nice 62 Merc Monterey tail lights and when you do, you can't afford them. So, I made some 59 Caddy lights work. I know a lot of people use the caddy lights, but they are similar in size to what I already have. ImageUploadedByH.A.M.B.1439234285.909024.jpg
    Here are the original lights. Faded and cracked
    ImageUploadedByH.A.M.B.1439234362.135830.jpg ImageUploadedByH.A.M.B.1439234376.802282.jpg ImageUploadedByH.A.M.B.1439234458.191528.jpg ImageUploadedByH.A.M.B.1439234470.962585.jpg
    So to make this work, I had to replicate the base of the original tail light so that the Caddy light could attach to it and then to the housing. ImageUploadedByH.A.M.B.1439234612.815251.jpg i used 3/8 acrylic, traced the base of the original and cut it out. Made the necessary holes to attach the Caddy base to it. ImageUploadedByH.A.M.B.1439234747.680952.jpg ImageUploadedByH.A.M.B.1439234763.534056.jpg ImageUploadedByH.A.M.B.1439234775.919833.jpg I painted one side of the acrylic with red metal flake clear coat from Home Depot. (Painted it before pictures) ImageUploadedByH.A.M.B.1439234908.934627.jpg Anyway, I attached the Caddy light to the new base and set in to the housing and this is what I got. ImageUploadedByH.A.M.B.1439235072.636975.jpg ImageUploadedByH.A.M.B.1439235086.972141.jpg ImageUploadedByH.A.M.B.1439235106.975051.jpg ImageUploadedByH.A.M.B.1439235117.309700.jpg ImageUploadedByH.A.M.B.1439235130.292020.jpg
    Stu D Baker likes this.
  2. Cortney
    Cortney
  3. 40fordtudor
    40fordtudor
    Looks pretty good---I've seen Caddy lenses run in lots of worse places.
  4. Cortney
    Cortney
  5. luckythirteenagogo
    luckythirteenagogo
    It looks good from here...
  6. SicSpeed
    SicSpeed
    from Idaho
    That looks great.
  7. Hnstray
    Hnstray
    from Quincy, IL
    That's probably the very best adaption of Caddy lights I've ever seen. Looks very good and is appropriate to the stock Merc bezel. Congratulations on your creativity, workmanship and good taste!:)
    Ray
    acjcf2, 40fordtudor, Squablow and 5 others like this.
  8. Spud
    Spud
    from Ohio
  9. Cortney
    Cortney
    Thanks!! I appreciate that!!
  10. I'll nitpick this a bit, mainly because you see this all the time and guys don't think about the safety factor...
    Nearly all state laws require that you have a red reflective lens on the rear of your vehicle; in this case, that is located on the flat base of the OEM lens. These are usually part of the lens (like here), but not always; some vehicles have them as separate items ('59 Caddy's had them in the bumper, my OT '13 Mustang has them in the lower rear fascia)). I believe these have been required on all cars starting in the 50s. These are generally required to be visible out to at least 300'. This is to ensure that even if the taillights aren't working, if light falls on the rear of the vehicle it will be seen. So if you're driving the vehicle and the taillights go out, somebody coming up behind you will hopefully see these reflectors and know you're there, or if the vehicle is parked. Given all the concern that has been expressed about rear visibility (people looking for brighter taillights), ignoring this is surprising.
    The 'fix' here is easy; pick up some red reflective tape and apply it to the 'adaptor', more or less duplicating the OEM reflective surface.
  11. Cortney
    Cortney
    Crazy Steve, thank you for the info.
  12. Man, that looks awesome. Good job
  13. Great fab work.
  14. 55Brodie
    55Brodie
    Finally a 59 Caddy tail light that looks like it belongs. Bravo, sir.
  15. Jalopy Joker
    Jalopy Joker
    great plan and execution - agree with Crazy Steve - might consider an upgrade to Brite bulbs or LED bulbs.
  16. Jalopy Joker
    Jalopy Joker
    great planning & execution - good info from Crazy Steve - might consider Bright bulbs or LED bulbs
  17. Drive'em
    Drive'em
    I think it looks waaay better than the stock unit. Great job!
  18. cretin
    cretin
    Normally, I would say that the only thing a '59 caddy taillight looks good in is a '59 caddy. This is the exception to that rule. Nice work.
    40fordtudor likes this.
  19. Cortney
    Cortney
    Thanks for all the positive input! Means a lot to me!
  20. gimpyshotrods
    gimpyshotrods
    Finally, a proper non-stock application!
  21. Cortney
    Cortney
    ImageUploadedByH.A.M.B.1439346585.502417.jpg finished and working
    rytang likes this.
  22. Squablow
    Squablow
    Looks great, one of the very few good uses of '59 Caddy tail lights.
  23. SicSpeed
    SicSpeed
    from Idaho
    That looks great.
  24. 1936dodge
    1936dodge
    Nice.Looks like it was made for it.
  25. Lowliner
    Lowliner
    Luv it !!! Perfect look. Way better than stock !
  26. Cortney
    Cortney
    Thanks!! I appreciate the comments!
  27. Muttley
    Muttley
    I'm not usually a fan of those lights at all but they look great on that car............even better than they do on a '59 Caddy.
  28. Okie Pete
    Okie Pete
    Looks great like they can on the car.
