What do you guys recommend to use when drilling or cutting plastic tail light lenses? I am looking at cutting a large hole in the center of my tail light so that I can push through a cone shaped lens and glue/epoxy it to the original lens. Any hints or suggestions on what to use to do the cutting and what to use for keeping the two pieces together?
I would think a hole saw would work, just keep it slow so it actually cuts the plastic, not melt it. Maybe use a drill press so the work and/ or bit doesn't move around on you. Model glue, super glue will work to keep it together.
Thanks fellas, I totally forgot about the glue for my model trains. That stuff is great, it bonds plastic and dries clear. Good call ! ! !
I wouldn't drill through it with a bit, I'd use a cutoff wheel or rasp bit on a Dremmel rotary tool. The bit will shave through the plastic instead of cutting it. Then work out to the hole size with a sanding drum bit or rasp. Larger drill bits can bite into the plastic and crack it. On the plastic sheet stuff. I have the best luck cutting plastic with real thin cutoff wheels on an angle grinder, jigsaw teeth will bite in and crack too.
use 2 part epoxy... water is the nature enemy of super glue , tail lights are out in the elements. be sure to mask off any areas you dont want the epoxy to get on.
